Drag vs Greddy Turbo kit
Re: Drag vs Greddy Turbo kit (TorganFM)
between the two, i would rather go with drag cause imo, the greddy kit includes a tiny turbo which is good but id rather have overall power.
Personally i would just peice a kit together, that way you get to pick everything that you want. but if this is your first time turboing, then buy a kit, unless you have someone that will walk you through it.
Re: Drag vs Greddy Turbo kit (EF8_Fan)
I don't have someone that wants to walk me through it, unless you do . The main problem with piecing it together is getting the piping right. I can pretty much gather up everything I would need except the piping, which would be custom for each particular job.
the only hard part for piping is from the turbo to the IC. the rest is easy. Im sure people will help you but they will all bitch at you to search first. if you need any help feel free to ask. i dont know everything, but i can help you out with what i do know.
nope sorry, it really depends on your setup for which ic piping you need to use. you can buy individual peices from jc whitney. what mani dp and turbo are you using
haddyback
10-12-2002 08:45 PM
