Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup?
Old 11-01-2003, 03:56 AM
Spooled1.6L's Avatar
Default Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup?
IM looking to get 350 - 400 whp. Just wondering if thats possible with the drag set up?
Old 11-01-2003, 06:41 AM
11psiTurboSI's Avatar
Default Re: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup? (Spooled1.6L)
Yes!
Old 11-01-2003, 06:48 AM
Default Re: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup? (9psiTurboSI)
thank you, do you have any numbers or info to back that up
Old 11-01-2003, 06:57 AM
https://honda-tech.com/zerothread?id=653254
He made 395hp and 375tq only difference is he has a gem block 83mm and a ls motor but you get the idea
Old 11-01-2003, 07:33 AM
nice numbers thanks alot.
Old 11-01-2003, 01:42 PM
tmkpres's Avatar
My b16 with the drag kit is making 310 to the wheels not as high as you want it but I know it can make more power if I retune it
Old 11-01-2003, 01:58 PM
Default Re: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup? (tmkpres)
how much boost is that? And what all do you have?
Old 11-02-2003, 01:22 AM
crazyitr's Avatar
https://honda-tech.com/zerothread?id=664355
Old 11-02-2003, 03:52 PM
turbo Si's Avatar
Default Re: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup? (crazyitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyitr &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=664355</TD></TR></TABLE>
What's up Usef. I think he was asking about a DRAG kit on a B16. Fortunately Jamil's car is pretty much custom.
Depending on your compression ratio it's possible. You will have a better chance with a t3t4e rather than a t3t4b which is the turbo that comes in the Si kits.
Old 11-02-2003, 04:10 PM
B18B1DOHC's Avatar
Default Re: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup? (turbo Si)
does that mean..lower compression will make ur car faster than higher compression? (turbo-wise)
Old 11-02-2003, 05:02 PM
illi Adik's Avatar
Default Re: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup? (B18B1DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B1DOHC &raquo;</TD></TR><TR><TD CLASS="quote">does that mean..lower compression will make ur car faster than higher compression? (turbo-wise)</TD></TR></TABLE>
No, higher compression will always make more power its just the fact that when running boost you have to worry about detonation. Lower compression aids in this by allowing more boost to be run and power to be made. Do you have stock sleeves? what kind of fuel do you plan on running?
BILLY_BLING
01-07-2007 06:21 PM
dohcdawg
03-13-2005 07:02 AM
Kermit EK
12-26-2002 07:50 PM
SiBirdie
08-13-2001 08:34 PM
Quick Reply: Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup?
