oil feed... how to reduce flow....
Old Oct 30, 2003 | 12:59 PM
TurboSam's Avatar
Default oil feed... how to reduce flow....
i am just wondering if it is possible that i am running too much oil into the turbo, causing it to go past the seals. i am runnin a -3AN feed and a -10AN return on an H22, oil pressure is about 30psi at idle, a little over 50psi normal driving, and 75-80 at higher RPMS at WOT. i am pretty sure my oil burning is at the valves guide seals, i am just wanting to make sure
Old Oct 30, 2003 | 01:02 PM
TeStUdO's Avatar
Try this link it could possibly help you out.
https://honda-tech.com/zerothread?id=653778
Old Oct 30, 2003 | 01:12 PM
TurboSam's Avatar
Default Re: (TeStUdO)
how the F did i overlook that thread
slooogsr's Avatar
wow....... 30psi at idle???
im only at about 10-15lbs at idle and 60 when warm around 3k
Old Oct 30, 2003 | 01:14 PM
TurboSam's Avatar
Default Re: (sloorex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex &raquo;</TD></TR><TR><TD CLASS="quote">wow....... 30psi at idle???
im only at about 10-15lbs at idle and 60 when warm around 3k</TD></TR></TABLE>
yea, the pressure guage reads right at 25
Old Oct 30, 2003 | 01:42 PM
TeStUdO's Avatar
Default Re: (Turbo Sam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote">how the F did i overlook that thread </TD></TR></TABLE>
NP, im here to help. Good luck on lowering oil pressure
es_squared
May 10, 2009 01:38 AM
sik_tC
Dec 20, 2008 01:20 PM
AsSanitySlipsAway
12
Aug 27, 2006 09:55 AM
zexifiedlude
Jul 2, 2006 07:18 AM
JDM_SOHC
Dec 1, 2005 10:13 AM
