help!!! something weird sound ONLY when decelerating!!!!! wtf!>??!?!?!?!!>>>>>>
Old Oct 31, 2003 | 05:30 PM
reignofchaos's Avatar
Default help!!! something weird sound ONLY when decelerating!!!!! wtf!>??!?!?!?!!>>>>>>
Ok, when i'm driving and pressing the gas, even any gas, like 2% thorttle, there is no sound, but once i let go and let the car decel in any gear, i hear this continous squeaking noise.... could this be the turbo or some other ****????
i tried just clutching in and going into neutral while slowing from 50 or so, no noise, it's only when the engine is under decel load it makes the noise.. maybe turbo is still getting some exhaust pulses to drive it and it's squeaking???
i even tried going into neutral and just revving it, revving it while slowing down in neutral didn't make noise either!!!! wtf is going on??????????
d16y8
ihi rhb5 turbo
450cc
smc 500
Old Oct 31, 2003 | 08:01 PM
Default Re: help!!! something weird sound ONLY when decelerating!!!!! wtf!>??!?!?!?!!>>>>>
Old Oct 31, 2003 | 09:26 PM
Drew Peacock's Avatar
Perhaps your gearbox main bearing is on the way out, listen (carefully) at idle does it make a noise with the clutch not engaged and then go away once you engage the clutch? Just an idea this happened to me.
Old Nov 1, 2003 | 02:10 AM
falcongsr's Avatar
What is this crap?
aka throwout bearing. replace, problem solved.
Old Nov 1, 2003 | 04:03 AM
civictypenos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">aka throwout bearing. replace, problem solved.</TD></TR></TABLE>
agreed,sounds like a throwout bearing.
Old Nov 1, 2003 | 06:15 AM
2000vsm's Avatar
Default check
check the pedal
Modified by 2000vsm at 10:37 AM 11/1/2003
Old Nov 1, 2003 | 06:38 AM
Default Re: check (2000vsm)
throw out bearing??? i just changed to a new one in august with my new clutch! everything is all lubed up! damn it, not going to open up my trans for that damn bearing
it seems to only squeak when declerating, not acceleration.. so it's not the turbo?
Old Nov 2, 2003 | 07:20 AM
falcongsr's Avatar
What is this crap?
Default Re: check (reignofchaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reignofchaos &raquo;</TD></TR><TR><TD CLASS="quote">
it seems to only squeak when declerating, not acceleration.. so it's not the turbo?</TD></TR></TABLE>
how could it be the turbo? did u install the clutch?
Gravey
Jul 5, 2009 06:50 PM
looneytoonz
Nov 10, 2007 06:14 AM
quikrpm'z
Mar 11, 2004 04:42 AM
RC_SKUBY
Nov 9, 2003 10:22 AM
boost killz
Dec 30, 2001 12:00 AM
