blows oil through dipstick
Old Apr 24, 2005 | 02:24 PM
turbo_b16_ex's Avatar
Default blows oil through dipstick
title pretty much says it. under load/ boost it blows oil through dipstick tube WITH the dipstick on
Old Apr 24, 2005 | 02:31 PM
adeihl's Avatar
your presurezing the crank case. Do you have a breather? if you do, you are getting massive amounts of blow by. i fear your rings/ringlands a warm crispy pieaces of bread.
Old Apr 24, 2005 | 02:41 PM
s2kdre's Avatar
Default Re: (adeihl)
how much boost are you runnin? Let me know so i can help you better.
Old Apr 24, 2005 | 02:51 PM
it does it after a few seconds of any amount of boost. and yes i have breather valve on. I dont think it has massive blow by because it doesnt shoot burnt oil through the valve cover at idle or when i rev it up. its wierd.
Old Apr 24, 2005 | 03:07 PM
Boosted2K's Avatar
Default Re: (turbo_b16_ex)
Are you talking about a breather on the valve cover?? You should be venting the crankcase itself. The endyn kit seems to work perfect IMO, although I have had people have problems with it, maybe install error?
Old Apr 24, 2005 | 03:52 PM
how exactly does the endyne kit work?i dont know what i could have installed wrong to where it wouldnt vent properly
Old Apr 24, 2005 | 04:11 PM
Boosted2K's Avatar
http://www.theoldone.com/components/breather/
Works exactly how it reads, Stan at fast-turbo usually has these in stock, quick shipping b/c he's local to us.
Some people will tell you not to buy it b/c it's over $100. They say you can get the same fittings for the block from honda, I think a prelude part no. or something. But they are not the same as the endyne ones, which are modified to prevent oil from filling the can.
Old Apr 24, 2005 | 05:15 PM
that seams very similiar to a oil catch can. It states that it is used to catch VAPORS not a **** load of oil lol. i just dont know what the **** to do. my b16 did the same thimng. Im thinking that I have internal problems with my engine, not something that that kind of product is going to fix. There are plenty of people running much more boost than I do and do not have this problem. Im only running 8 psi with the POS ss autochrome turbo, so its that much cfm in there.
jdmtiiteyo
Jan 1, 2008 06:40 PM
the.hamburglar
Aug 31, 2007 08:52 PM
Dr Pooface
Sep 26, 2006 08:36 AM
Integra GSR 95
May 24, 2006 05:07 PM
The-LS
Apr 18, 2003 04:32 AM
