Got my Built Motor Tuned
I got my car tuned today by Ed Senf at Balanced Performance. Setup is: Golden Eagle Sleeved 84mm B18C1, JE 9:1 Pistons, Eagle Rods, ACL Bearings, 1mm oversized Ferrera Valves & Guides, Skunk2 Springs & Retainers, Cometic HP headgakset, Gasket ported and polished head, stock GSR cams, JG Edelbrock Victor X Intake Manifold, JG Edelbrock 65mm throttle body, AEM Fuel Rail, SX Fuel Pressure Regulator,-6AN Fuel Lines, Fluidyne Radiator,97 GSR transmission, MSD SCI & MSD BlasterSS External Coi),modified GReddy Oil Catch Can w/ breather added, -6AN Oil Catch Can Stainless Steel Lines
Turbo Setup: Neukin Manifold, Garrett T3/60-1 .63 a/r exhaust housing, Tial 44mm Wastegate, Tial 50mm BOV, Precision 750hp Intercooler, Turbonetics Couplers and T-Bolt Clamps, GReddy TVVC MBC, full 3 inch Kteller cat back with Apex N1 muffler
I'm happy with the results. I cant wait to take it to the track and get some good times
Blueline= high boost(27psi on 4 gallons C16 and 2 gallons 93)
Red line=low boost(10-11psi on 93 octane)
Modified by RotiEatter at 2:06 PM 4/21/2005
Re: Got my Built Motor Tuned (RotiEatter)
[/QUOTE]
Red line= high boost(27psi on 4 gallons C16 and 2 gallons 93)
Blue line=low boost(10-11psi on 93 octane)
[/QUOTE]
Great numbers, but i think you mean blue line is high boost and red line is low boost. haha. Unless you make less power on high boost and race gas.
[/QUOTE]
official honda whore
nice setup and nice numbers lowboost setup should last you a very very long time for a daily driver and be more then enough power to put most street cars behind you
Re: Got my Built Motor Tuned (FyReo3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FyReo3 »</TD></TR><TR><TD CLASS="quote">What size injectors are you running?</TD></TR></TABLE>
880 i think he said!!!
VERY NICE!!!!
VERY NICE!!!!
Who is Mr Robot?
Re: Got my Built Motor Tuned (2000civicsi)
nice numbers. i thought about letting ed tune my car, but i think im gonna supply my own tuner and just pay em to use the dyno time
Re: Got my Built Motor Tuned (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">nice numbers. i thought about letting ed tune my car, but i think im gonna supply my own tuner and just pay em to use the dyno time</TD></TR></TABLE>
If you plan on doing that then don't go to Balanced, I called about doing that before and they were way to expensive.
Yea I am running MSD 880's
Re: Got my Built Motor Tuned (FormulaGSR)
1.) He has a boost controller (possibly in the car), that he just turns up. Basically the car is tune to 27psi, but he may lower the boost controller to limit it to 10psi.
2.) More likely (since it would be using race gas instead of pump), is that he has two chips that he can open the ECU and swap them as well as the boost controller.
Re: Got my Built Motor Tuned (Dunc)
I see u got OEM mounts, spend a couple more $ and get some HASport mounts, especially the rear and drivers side mount.
or just tune it for pump gas and throw in race gas and only make better power, you dont have to make a seperate tune for race gas, it will give you the power like it not
