Finished Install...IDLE LOPING..NO BOOST!
Old Apr 22, 2005 | 11:13 AM
JD95hatch's Avatar
Default Finished Install...IDLE LOPING..NO BOOST!
Alright...heres the problem...i just finished my swap/install and am having an idle problem...the engine is UNTUNED, i switched between both AFC hack/stock p28 and a chipped p28 with basemap and still engine reacts the same way.
I will fire up the engine and it will being to lope once it gets up to temp...650-720rpm and eventually cut out..
When i was driving the car, i brought it up to 4500rpm...normally i hit boost around 3500 but this time..nothing...my boost guage still read in vacuum.
What do you think??
Modified by JD95hatch at 3:24 PM 4/22/2005
Old Apr 22, 2005 | 02:04 PM
Blazin Civic's Avatar
Default Re: Finished Install...IDLE LOPING..NO BOOST! (JD95hatch)
Check for vacum leaks. Also check the couplers on the charge pipes.
Old Apr 22, 2005 | 02:33 PM
Dragline's Avatar
Default Re: Finished Install...IDLE LOPING..NO BOOST! (Blazin Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote"> Check for vacum leaks. Also check the couplers on the charge pipes.</TD></TR></TABLE>
Old Apr 22, 2005 | 02:55 PM
vaporboy12's Avatar
Default Re: Finished Install...IDLE LOPING..NO BOOST! (dragline)
check map sensor
Old Apr 22, 2005 | 05:30 PM
h22 civic's Avatar
Default Re: Finished Install...IDLE LOPING..NO BOOST! (vaporboy12)
what is you car vacuming at idle ?
Old Apr 22, 2005 | 05:33 PM
mamaboy's Avatar
check v @ map sensor
Old Apr 22, 2005 | 08:23 PM
IN VTEC's Avatar
What kind of software was used to create the startup map?
I've run into similar symptoms before. Low idle vacuum (~19" Hg), rough warm idle, and low warm idle. The problem was that the fuel basemap was too lean...way too lean...around 24:1 AFR.
Old Apr 22, 2005 | 08:28 PM
JD95hatch's Avatar
Default Re: Finished Install...IDLE LOPING..NO BOOST! (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">What kind of software was used to create the startup map?
I've run into similar symptoms before. Low idle vacuum (~19" Hg), rough warm idle, and low warm idle. The problem was that the fuel basemap was too lean...way too lean...around 24:1 AFR.</TD></TR></TABLE>
well..i rule that out becuase the problem was present with BOTH fuel managements
but didnt check the vacuum number...will do tommorw..
Old Apr 22, 2005 | 08:29 PM
JD95hatch's Avatar
also..i swapped map sensor from old engine over...so im hopin its just a vacuum leak...
Old Apr 22, 2005 | 08:34 PM
IN VTEC's Avatar
What size injectors are you using? And, does the "chipped" ECU's ROM have the proper injector correction factor?
Old Apr 22, 2005 | 09:02 PM
JD95hatch's Avatar
like i stated...it shouldnt matter becuase when i ran the chipped ECU...chipped with a basemap from uberdata it ran the same when i swapped ECUs and ran the AFC Hack
but im sure my ECU guy is good for his work....
Old Apr 23, 2005 | 04:42 AM
Dragline's Avatar
Old Apr 23, 2005 | 05:41 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch &raquo;</TD></TR><TR><TD CLASS="quote">like i stated...it shouldnt matter becuase when i ran the chipped ECU...chipped with a basemap from uberdata it ran the same when i swapped ECUs and ran the AFC Hack</TD></TR></TABLE>
Maybe they're both improperly calibrated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch &raquo;</TD></TR><TR><TD CLASS="quote">but im sure my ECU guy is good for his work.... </TD></TR></TABLE>
I assumed the same thing too....until I double-checked his work. We're talking about a reputable guy. It was probably just an oversight, but you can't always take everything for granted, especially when it comes to Uberdata startup map hand-outs.
Old Apr 23, 2005 | 09:45 AM
JD95hatch's Avatar
Even though it revs fine u still think it could be running lean??
Old Apr 24, 2005 | 12:20 PM
IN VTEC's Avatar
Yes. In my scenario, the car drove an hour down to me before I found out how lean it was.
Aside from the idle vacuum being a bit low, it drove fine for the most part, but it would buck quite a bit on throttle changes and throttle on conditions.
Old Apr 25, 2005 | 03:52 PM
JD95hatch's Avatar
finally got some vacuum numbers...idle ~ 21psi 4k RPM ~14psi.
could i have my BOV adjusted so that all the boost is escaping?...i have a greddy type S
zachsbat1
Apr 24, 2008 05:04 PM
BoostedEgHatchFl
Aug 25, 2005 03:22 AM
hatchedzex
Jul 18, 2004 05:47 PM
Blazin Civic
May 31, 2004 09:41 AM
chinners10
Sep 29, 2003 08:18 PM
