steel braided oil return line- how long do i need it
i am building my oil return line. i am getting the fittings and need to know how long i need to get the steel braided line. this is cheaper for me instead of a kit because my dads company can get them cheap through aeroquip, the company he works for just bought them. i have a 96 gsr with the drag kit, t3/t4 turbonetics turbo and a moroso oil pan. any ideas? thank you!
Risky Business
Re: steel braided oil return line- how long do i need it (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">hmm i want to say liek anywhere from 12 inch to 16 inch. It always good to have it a bit longer, then just cut it.</TD></TR></TABLE>
Yup
Yup
Re: steel braided oil return line- how long do i need it (BauleyCivic)
well i just want i tto alreay have the treaded fitting on it....how do u put the fitting back on if you have to cut it?
Re: steel braided oil return line- how long do i need it (JDMwhiteDC2)
My kits are supplied with a 14" drain hose, but I don't know if anyone has ever used the full length. I would say get about 12" and cut it if neccessary.
AN fittings are made to be tight, so they are a little tricky to put back on, but it's more than possible.
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMwhiteDC2 »</TD></TR><TR><TD CLASS="quote">well i just want i tto alreay have the treaded fitting on it....how do u put the fitting back on if you have to cut it?</TD></TR></TABLE>
Uh, unscrew it and take it off?
the steel line with the female fitting on the end of it just screws off? i still dont get it. sorry. ive never seen on close up...thanks for all the quick replies.
