Block setup for (450-500hp)
Old Apr 20, 2005 | 02:21 PM
GsRHatchy1320's Avatar
Default Block setup for (450-500hp)
im just curious to know and if u care to share your block setup. What type of sleeves, pistons what bore size ..etc are u using. Preferably people thats getting 450-500hp range. I have a gsr block im building its my first build, and i want to build it right..So any suggestions would be appreciated Thanx
Old Apr 20, 2005 | 02:51 PM
SEFIxCivic's Avatar
Default Re: Block setup for (GsRHatchy1320)
im running crower rods, wiseco pistons, 81mm ge sleeves w/ arp headstuds, and a balanced crank w/ micropolished and chamfered holes. i made 602 whp.
Old Apr 20, 2005 | 03:27 PM
i was plan on running eagle rods, wiseco pistons, aebs sleeves. The person thats sleeving my block suggests i should do 83 in my bore size not to sure on that. anyone else with there setup or have some suggestions?
Old Apr 20, 2005 | 03:57 PM
lalspeed's Avatar
Default Re: (GsRHatchy1320)
not that i have first hand experience but its kinda common sense bro
bore size doesnt really matter till u hit 84.5, then u may be gettin on the thin size, alothough i remember seein a 86mm turbo b16, but thats besides the point lol
83 is a good place to start as you have room for improvement, all it has to do with is displacment
good luck with it man
Old Apr 20, 2005 | 04:35 PM
SPOOLINmatt's Avatar
Default Re: (lalspeed)
weve been running 447 whp on stock bore stock sleeve gsr block for over a year now beating it on a daily basis. build for your goals, 447 is FAST. if you want more than yeah sleeve it. Tune it good.
Old Apr 20, 2005 | 04:50 PM
tony n.'s Avatar
Default Re: (SP00LIN)
gsr sleevs that strong?
Old Apr 20, 2005 | 06:29 PM
rmcdaniels's Avatar
408WHP on Darton open-deck sleeves, Eagle rods, Wiseco pistons, Honda bearings, 84mm bore on a B16
Old Apr 20, 2005 | 07:28 PM
Default Re: (boosted2cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">gsr sleevs that strong?</TD></TR></TABLE>
yes, any b series for that matter, they all use the same sleeves.
93delsolJDM
Feb 13, 2011 11:25 PM
phiberoptik
Aug 27, 2003 10:19 AM
swlabhot
Jun 20, 2003 12:41 AM
Brian_92GSR
Feb 9, 2002 07:31 PM
