Request : Oil Feed Line pictures and oil return pictures
i researched and found similar topics but the pics had all X out...so sorry for the repost kinda...
want pics of entire oil line setup...block to turbo, turbo to oil pan, and another line goes somewhere im not sure...jus need some pics to help me out...
i have a 95 gsr, t3/to4e turbo
thanks
thanks
i ♥ my honda
Global Mod
Global Mod
i ♥ my honda
Global Mod
Global Mod
Re: Request : Oil Feed Line pictures and oil return pictures (95BlkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR »</TD></TR><TR><TD CLASS="quote">common need some pics
I gave you dam good pics and if you want more then SEARCH!
There are plenty of non-dead pic links that work fine for me.
We are not here to spoon feed you.
Re: (IslandSi)
i just dont know where it comes off the block...i think its by the oil filter not 100% sure...i dont wanna go pulling things out and it not be the right thing
H-T White Ops
you need extra parts to make that work. Do a search for "tunertoys adapter" or "golden eagle sandwich". There's no place on a motor where you can just thread a feed line into.
I have a strong vibe that you'll be back in here in a couple of months asking how to do a compression test on your motor because it smokes like crazy now and is burning a LOT of oil.
Re: (IslandSi)
GSR doesn't have a place for oil feed? the b16 does... hmm I wondered why people needed those adaptors...
here you can see my hole 1" to the left of the oil filter..
here's the return line...
I know I murdered the fittings with channel locks. this is a b16 but I felt bad no one else wanted to show pics...
good luck!
ps: your just adding a feed line, return line, and hopefully a line tapped from your feed source to the oil pressure gauge... thats it
good luck!
H-T White Ops
Re: (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 »</TD></TR><TR><TD CLASS="quote">GSR doesn't have a place for oil feed? the b16 does... hmm I wondered why people needed those adaptors...
ps: your just adding a feed line, return line, and hopefully a line tapped from your feed source to the oil pressure gauge... thats it </TD></TR></TABLE>
He's still going to need some kind of adapter. The threads in the block are NOT NPT threads that every feed line I've ever seen needs. He's going to need some kind of an adapter.
H-T White Ops
Re: (95BlkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR »</TD></TR><TR><TD CLASS="quote">cant i just take out the il pressure sensor and put it there? and move the sensor to a side of a T ?</TD></TR></TABLE>
Which is something you would have been able to answer had you searched for that Tunertoys(z) fitting like I told you to.
Re: Request : Oil Feed Line pictures and oil return pictures (platinum00)
short oil return...i got 3ft of -10 an SS Hose...guess i need like 5 inches...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
use oil resistant hose for return line. some performance shops will have such lines, or industrial type places, even plumbing will have red multi-purpose hoses that are oil resistant
