wastegate hits hood
wastegate hits hood
alright heres my set up I got a 94 EG coupe with B18B with a Rev hard manifold and a tial 38 mm wastegate and a VIS carbon fiber hood but when I go to shut my hood the wastegates hits the hood and it needs about .5 of in to shut any body know any thing about this or have the same problem thanks
Re: wastegate hits hood (Lmgrcivic)
I put some shims under the hood latch (hood side). I just used a couple washers and it worked fine. If you shim too much your hood will be too high for your quarter panels. Good luck.
Re: (Da K00l Aid Mayun)
I have the same set up except w/ an inlinepro mani. I also have the VIS hood. The cheapest thing to do is get a brass 90 degree nipple to put on top. It sits lower than the bulky banjo one that comes w/ the tial. Then you take a dremel and just take a small notch out of the hood under skeleton/reinforcement. It doesn't take much trimming and it's easier than getting a new elbow/dump tube.
