cleaning an intercooler
Old Apr 23, 2005 | 02:30 PM
turbo_b16_ex's Avatar
Default cleaning an intercooler
hey ive tried alot of ways to cleaning my intercooler, and i havnt found a good way. let me know how yall do it.
Old Apr 23, 2005 | 03:27 PM
Calvinator's Avatar
Default Re: cleaning an intercooler (turbo_b16_ex)
try using an air compressor and blow the dirt out of the fins
Old Apr 23, 2005 | 04:28 PM
N20civicB18's Avatar
pull ur wastegate off j/k Personally I would use hot water and degreser with some compressed air - just be careful also make sure its dry before you put it back on
Old Apr 23, 2005 | 05:05 PM
SOHCmaster's Avatar
prestone flush kit, then rince clean and air hose it dry.. Ive used cerocene and gas once too,..
Youll be surprised how dirty it gets in there when you just use a screen for filter on your turbo and drive it all winter etc,..
Old Apr 23, 2005 | 05:39 PM
Laserjock's Avatar
Default Re: (PK SPEED)
yes gasoline worked for me in the past. another method is brake parts cleaner works very well.
Old Apr 23, 2005 | 06:18 PM
Sprockets's Avatar
Default Re: cleaning an intercooler (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">try using an air compressor and blow the dirt out of the fins</TD></TR></TABLE>
This is a bad idea. I've done it, and it bent the fins. Same thing with water.
Old Apr 23, 2005 | 06:47 PM
im talking about cleaning the front of it. cleaning out the insides no problem, just keepn the out side bling blingn is kinda difficult
Old Apr 24, 2005 | 12:59 PM
Calvinator's Avatar
Default Re: cleaning an intercooler (B16A Grenade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade &raquo;</TD></TR><TR><TD CLASS="quote">
This is a bad idea. I've done it, and it bent the fins. Same thing with water.</TD></TR></TABLE>
well, i wouldnt aim the spray nozzle up close to the fins, just from a distance. I guess the brake cleaner idea would be better.
crxricer66
Aug 23, 2007 07:26 PM
Mikes2000civicsi
Jul 31, 2007 07:00 PM
Farmer Brown
Feb 16, 2004 11:15 AM
94TealGSR
May 11, 2003 10:01 PM
johnisenglish
Apr 22, 2003 06:35 PM
