My h22a turbo setup, what you guys think.
I currently swapped a h22a into my del sol. I drove it for like 2k and I got board so now im going to boost it. Here is my part list
t3/t4 60 trim
custom mani
450cc dsm
jrc 5 inch
2.5 inch dwn pipe and charge pipes
p28 with iab control, uberdata
I have been researching about the issues with the h22a and boost and it def worries me. My plan is basically to run 7-8 psi max prob 6 cuz im a ***** with moderate timing. I dont even plan on boosting the car untill I strap the bitch to a dyno. Like I said ive been researching it alot. Looking for some advice from people who have boosted h22a in this fashion, not the misleeding rumor bs thats associated with the h22
t3/t4 60 trim
custom mani
450cc dsm
jrc 5 inch
I won't sprout misleading information but here goes. I had almost an identical setup. I had a 18G turbo and i just modified the ic piping to fit with a CCA ic. I didn't skimp on engine management and went with AEM EMS. The p28 with uberdata always gave me a solid CEL, never figured why. Since then I got a new harness and rewired it. I ran about 6psi of boost and it didn't really last that long but the engine had about 100k miles on it. It lasted about 5 months. Then I got ridiculous blow by. It came from cyl 1... Tore it down, and behold a broken ringland. The oddest thing was there was no detonation, nothing. It was tuned properly. The engine just couldn't take it I guess. I found out the motor was a converted type s as I found type s pistons when it was torn down. Just have a good tuner and it should run great. Good luck.
Re: (bigblockvtec)
sounds like a good setup, but id recommend a 3" dp and 3" straight through exhaust - it will show tremendous gains.
When it comes to turboing an h22, its 50/50. Some make amazing power and some just blow. My first time around, the motor blew in like 100 miles, but that was because the balance shaft seal went.
Anyway, I say 8psi is feasible/reliable with a good tune. Should make somwhere in the 275-290whp range.
Goodluck
Goodluck
1fastvtec
04-20-2005 09:26 PM
