AEM UEGO controller range?
Old Apr 24, 2005 | 06:07 PM
Yani's Avatar
Default AEM UEGO controller range?
what a/f range will the uego (gauge type) read? will it go all the way down to 10:1? lower?
Old Apr 24, 2005 | 06:23 PM
11psiTurboSI's Avatar
Default Re: AEM UEGO controller range? (Fst Blk GTi)
10:1 is the lowest it reads
Old Apr 24, 2005 | 06:59 PM
JDogg's Avatar
Default Re: AEM UEGO controller range? (11psiTurboSI)
the guage will only read to 10.9:1
the non guage type will read 9:1
the internal wb will read 10:1
Old Apr 24, 2005 | 07:24 PM
Yani's Avatar
Default Re: AEM UEGO controller range? (JDogg)
so the actual gauge will only read down to 10.9:1. if i use the output from the wideband with an aem ems, or a profec e01 will it read lower than 10.9:1?
Old Apr 24, 2005 | 09:58 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fst Blk GTi &raquo;</TD></TR><TR><TD CLASS="quote">so the actual gauge will only read down to 10.9:1. if i use the output from the wideband with an aem ems, or a profec e01 will it read lower than 10.9:1?</TD></TR></TABLE>
nope
why would you need it to read that rich anyway?
Old Apr 26, 2005 | 07:52 AM
Yani's Avatar
its for tuning a srt4 with an sc61, from all the setups i've seen these cars like t run best at high 10's low 11's.
Old Apr 26, 2005 | 09:20 AM
JDogg's Avatar
thats weird, i have tuned alot of different cars and never seen one that made better power running that rich, even rotarys. i have never messed with an srt4 so who knows
Old Apr 26, 2005 | 09:22 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fst Blk GTi &raquo;</TD></TR><TR><TD CLASS="quote">if i use the output from the wideband with an aem ems, or a profec e01 will it read lower than 10.9:1?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">nope</TD></TR></TABLE>
That’s not true JDogg you are contradicting yourself...
As long as you have the non-gauge type WB that does not require the gauge to work than your controller will read to 9:1 And if you have the gauge type it will read to 10:1
Old Apr 26, 2005 | 09:48 AM
JDogg's Avatar
Default Re: AEM UEGO controller range? (White Smoke)
you are right, the guage type will output a signal down to 10:1, the guage just wont display anything below 10.9:1
the NON guage type will read down to 8.5:1. if you have something to display the readings with then that will work fine.
the built in wideband will read down to 10:1
red beast
May 2, 2007 08:49 AM
Accord_boy619
Oct 30, 2005 05:49 PM
tegon-gsr
Mar 29, 2005 09:11 AM
BoostedH23a1
Dec 15, 2003 11:30 AM
2K_TEG
Nov 9, 2003 07:43 PM
