How to adjust fuel on V-AFC?
Old Apr 22, 2005 | 04:46 PM
Aracheon's Avatar
Default How to adjust fuel on V-AFC?
I know how to adjust the fuel settings on a VAFC, but the manual that came with it wasn't very informative in terms of which way I go to add or subtract fuel.
If I went from -38 to -34, would I be ADDING fuel, or REMOVING it?
Old Apr 22, 2005 | 05:04 PM
Cee_mon's Avatar
Default Re: How to adjust fuel on V-AFC? (Aracheon)
you would be adding 4% more fuel.
Old Apr 22, 2005 | 05:08 PM
Johnny_Rocket's Avatar
Default Re: How to adjust fuel on V-AFC? (Cee_mon)
so If I adjusted mine from +5 to +30 I would be ADDING 25% more fuel?
Running 6 pounds on a FMU with stock injectors what would you recommend I set it at?
Old Apr 22, 2005 | 10:01 PM
Cee_mon's Avatar
Default Re: How to adjust fuel on V-AFC? (JohnnyH)
FMU already bumps up fuel for you. I would leave the VAFC close to 0.
And yes you are correct going from +5 to +30 is plus 25%
Old Apr 22, 2005 | 10:12 PM
SOHC_MShue's Avatar
you would be adding. The more negative you go the more you are taking out.
Old Apr 23, 2005 | 05:26 AM
Laserjock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aracheon &raquo;</TD></TR><TR><TD CLASS="quote">I know how to adjust the fuel settings on a VAFC, but the manual that came with it wasn't very informative in terms of which way I go to add or subtract fuel.
If I went from -38 to -34, would I be ADDING fuel, or REMOVING it?</TD></TR></TABLE>
the correct term is you would be taking out <U>LESS</U> fuel. if you are using an AFC (assuming you installed it to control injectors) why are you taking out so much. your setup?
Old Apr 23, 2005 | 05:56 AM
Aracheon's Avatar
The negatives were just an example, and yeah, that all makes sense!
Thanks!
dabrat8614
Aug 2, 2007 12:59 PM
integra15
Mar 21, 2005 12:05 PM
Toda Party
Mar 17, 2002 01:39 AM
oryanh
Jan 1, 2002 11:36 AM
Mike95lude
Oct 10, 2001 10:53 AM
