another turbo question
Old Apr 23, 2005 | 08:17 AM
stoopid_monkey's Avatar
Default another turbo question
Which turbo to get for a b16a2 motor? I'm not looking for huge power. I'm more into quick spool. A range of 220-260 at about 8-10 psi. No future plans.
Turbonetics T3 .54 trim super 60
Turbonetics T3/t04 .54 trim
GT25R
GT28R
GT30R
Old Apr 23, 2005 | 08:19 AM
Default Re: another turbo question (stoopid_monkey)
the gt25 and gt28 has internal wastegate. is that okay? if not, is there a way to make it external wastegate. how much psi' can the internal wastegate hold?
Old Apr 23, 2005 | 08:38 AM
a1320addict's Avatar
gt28r for sale....pm if intersted..only 1500 miles PERFECt condition
Old Apr 23, 2005 | 08:46 AM
Default Re: another turbo question (yehiknowrite)
assuming you said GT28R bc you wanna sell yours.
Old Apr 23, 2005 | 08:56 AM
i want to sell it yes
but judging by garrets flow charts...a gt28r or gt28rs is the perfect turbo for that motor...and i have seen it hit 225ish at 7 psi on a b16....so check it out....
and unless your planning on making obscene amounts of power....which irepsect but personally am not into....the internal gate will be fine
Old Apr 23, 2005 | 09:19 AM
rmcdaniels's Avatar
A GT28R or a GT28RS would be great. Personally I'd go with the GT28RS, it will spool very quickly and you'll be right in the middle of its efficiency range at your power goals, plus it will make more power if you get your engine built later (I got 380 WHP out of mine, but that was pushing it). The GT30R would be massive overkill, the power range for it is 350-500.
Old Apr 23, 2005 | 09:58 AM
Default Re: (rmcdaniels)
What is the estimate full spool for GT28R?
Old Apr 23, 2005 | 10:08 AM
Default Re: (stoopid_monkey)
If not, what are other turbo choices for my motor and power level. I'm just in the field for quick spool.
Old Apr 23, 2005 | 10:50 AM
bump, need to know asap
Old Apr 23, 2005 | 12:28 PM
anyone know wats the spool rpm for gt28r
Old Apr 23, 2005 | 02:55 PM
spool up starts around 2800 or so on your motor....and i believe you should see full boost by around 3600
Old Apr 23, 2005 | 04:11 PM
Default Re: (yehiknowrite)
thats like a T3
Old Apr 23, 2005 | 05:51 PM
a straight t3....not a t3/t4 hybrid....straight t3s can take up to around 3600 to start making a nice amount of boost....dont forget....your motor is a 1.6...meaning your turbocharger will take a LITTLE bit longer to spool because its exhaust velocity is not the same as say a 1.8 liter....its not about the size of the turbocharger...its about its efficiency and what your goals are with the car
Old Apr 25, 2005 | 08:55 PM
should i get a ball bearing for the power i want? i have NO plans to upgrade the car later. its either a t3 or gt28r? im not sure which?
Old Apr 25, 2005 | 09:03 PM
ball-bearing isnt really for power...i mean it does help the turbo spool a little quicker etc...but from what ive seen it increases the life of the turbocharger...plus the 28r is watercooled...which is an added bonus...if you want PM me ...ill hit you up with my dyno chart from tuning this wednesday
Old Apr 26, 2005 | 11:21 PM
Comparing a GT28R and T3 .54 Trim, how many rpm faster will the GT28R be over a T3 considering that its ball bearing and smaller. Is it bad to have internal wastegate? Will GT28RS give me faster spool than GT28R?
Aaron@Xcraft
Dec 15, 2009 10:36 PM
4g4dcruisin
Aug 30, 2009 04:30 AM
dropgear
May 19, 2004 02:28 PM
*Boostwerks*
Oct 29, 2003 10:34 PM
