Converting internal dump to external = get rid of boost creep?
I am spiking to 12lbs at ~6k rpm on just a .25 bar spring currently. Obviously, this is not good.
So would you guys suggest re-reouting it to external to help fix my problem, or is the manifold design too poopy
Re: Converting internal dump to external = get rid of boost creep? (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">its the manifold and the rerouting of the wastegate dumptube back into the downpipe. </TD></TR></TABLE>
Yes, I know this.
But my question is, would i significantly reduce the amount of creep/spike by making the dump external?
Yes, I know this.
Re: Converting internal dump to external = get rid of boost creep? (SpeedingHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch »</TD></TR><TR><TD CLASS="quote">Yes, I know this.
But my question is, would i significantly reduce the amount of creep/spike by making the dump external?</TD></TR></TABLE>
yea, it will most likely reduce your boost creep. you should cut it off and cover the hole on the downpipe and run an open dump route
ur trying to run a 3.625 psi spring????? wtf, only way to fix that is to have a tiny down pipe and exhaust.....
Cramerox
05-20-2003 01:27 PM
