Need help quickly....stupid question
Old Jul 5, 2001 | 12:45 PM
Chip398193's Avatar
New User
Default Need help quickly....stupid question
Where do i put the tranny fluid in on my ls? Do i put it right where the dipstick is, if so, how do i maneuver it down there? i need help on the haul ***
Old Jul 5, 2001 | 12:49 PM
owen_the_soyboy's Avatar
Default Re: Need help quickly....stupid question (Chip398193)
do you have an auto or 5 speed???
here is what I DO know-
on my 5 speed GSR the tranny drain bolt is about 3 inches BELOW the tranny check/fill bolt.
I used a piece of tubing and a funnel to fill the tranny.. with I think it was 2.4 quarts after an overhaul (LSD install)... it need less with just a fluid change.
HTH.
Old Jul 5, 2001 | 01:17 PM
supadupamikey's Avatar
Default Re: Need help quickly....stupid question (owen_the_soyboy)
if its automatic, yank the dipstick (for the transmission, duh) and stick a long funnel in the hole.
after you fill it up, start the car, hold the brake down and move up and down through all the gears slowly, (ie.. park, reverse, drive, drive 2, drive 1 [or however it applies to your car]).
then check the fluid again
try not to overfill it, add a little bit several times, rather than dumping a bunch in at once
Old Jul 5, 2001 | 04:41 PM
vteg's Avatar
New User
Default Re: Need help quickly....stupid question (lilmikey77)
I thought on automatics, you are not supposed to check the tranny fluid until after you drive 20 minutes. Since it is supposed to be checked while hot.
mynameizstitch
Apr 26, 2007 12:26 PM
.one lane
May 2, 2006 05:38 AM
egyolk
Apr 29, 2005 12:33 PM
korndog
Jan 26, 2005 02:16 PM
People_Mover
Jul 25, 2003 05:18 AM
