Winow problems???
Old Jul 10, 2001 | 09:29 PM
InfamousRS's Avatar
Default Winow problems???
I have a 94 RS with power window, when I just the door with the window down it sounds like the window is going to break. Also my power windows are really rackety and un smooth when I open and close them, I want them to be smooth like my friend 96 ls???? Is there anything I could do about that? Oh, I wanted to ask you guys if you knew how to get smoke film off of windows? The owner of my car before me was a smoker, and I cant get that film off, it looks clean right after I wash the windows, but like 2 days later the film is back!!!! anyone have any sugestions?
[Modified by BLK94RS, 6:32 AM 7/11/2001]
Old Jul 10, 2001 | 09:33 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Win(D)ow problems??? (BLK94RS)
I suggest you learn to spell first.
Second, you need to clean the tracks and not slam your doors. Honda's and Acura's have very tight tolerances, and it's not necessary to slam the door to close it.
As for the smoker film, use something strong like simple green and a scouring pad (not metal) to remove all the crap on the windows.
Old Jul 10, 2001 | 09:37 PM
Darren94ls's Avatar
New User
Default Re: Win(D)ow problems??? (B18C-EJ1)
hey wussup, i also have a 94rs and have the same problem...i thought it was my door panels cause i replaced them, but i tried taking them out and putting them back in, but it didnt work.
anyone out there w/suggestions
thanks
InfamousRS's Avatar
I tried all kinds of cleaners, even some industrial stuff that is ment to take paint overspray off windows after you paint them!!! A guy I work with said I should try OxyClean. Think that would work?
Old Jul 10, 2001 | 10:06 PM
B18C-EJ1
Guest
Posts: n/a
Try using a "Bug and Tar" style cleaner. It works for me. Then clean the window with glass cleaner and RUB HARD.
Old Jul 11, 2001 | 05:20 AM
Mikes94's Avatar
Default Re: Winow problems??? (BLK94RS)
Hey BLK94RS,
Are you sure the film on your windows is smoke film?? I've had the same problem ... but its due to the protectant you use on the interior. When the car warms up (ie in the sun) the crap evaporates of the dash or wherever and condenses on the windows. Thats why it comes back after you've washed the windows. Horrible **** ... and a real pain when your drivin into the sun. All I can suggest is dont use protectant on the dash ... or at least water it down a bit. Hope this helps.
Mike
civiceg94
Jul 10, 2007 12:27 PM
holeeray
Mar 6, 2005 01:36 PM
mr devious illusions
Sep 5, 2004 09:17 PM
-=DFOX=-
Oct 29, 2002 07:36 PM
