torque converter
Old Jul 9, 2001 | 10:39 AM
Integra187's Avatar
Default torque converter
i have an auto teg and was thinking about getting a torque converter. I heard it helps shift the car like a manual. But someone had told me it will wear down my transmission. Is this true? And is there any bad things about a torque converter.
Old Jul 9, 2001 | 01:44 PM
GSRwBOOST's Avatar
Default Re: torque converter (Jay D Em)
Im not sure if htey make aftermarket "stall converters" for imports.. i think your referring to is similar to the domestics taht have lots of hp and an automatic.. i had a 2500 for my chevelle.. it holds off the power a little bit and then BAM at 2500 dumps the rest of it almost at once...
good luck.. havnt seen one for imports yet..
Old Jul 9, 2001 | 03:27 PM
360's Avatar
360
Default Re: torque converter (GSRwBOOST)
You can get aftermarket torque converters from http://www.levelten.com - you can get them to set a custom stall speed according to your setup (for instance, if your turbo spools at 3k rpm, you can set your stall speed at 3100 so that a second after the turbo spools, the transmission will lock up and maximum power will be transferred to the ground.)
Old Jul 9, 2001 | 06:42 PM
crookedletterd's Avatar
New User
Default Re: torque converter (Teken)
how do you know when you need to change the tranny fluid?
Old Jul 16, 2001 | 07:09 PM
Integra187's Avatar
i know this post is old but i have a question. Do you think that adding a torque converter and ecu will make my auto faster than a manual teg or will they run the same?
d16rice
16
Feb 21, 2024 07:41 PM
rotflmao
Jun 6, 2005 11:18 AM
gsrt2c
Jul 2, 2003 04:57 PM
PrecisionH23a
Oct 28, 2002 08:14 AM
