Wiring problems
Old Jul 8, 2001 | 06:37 PM
bigTom's Avatar
Default Wiring problems
ok... iv rippeed apart and cut up most of my harness now... but i am confused what some wires are for... the first pic is the first issue... i cut off most of the wires leading to this... all which happen to lead to the abs... but ther a re a few wires that came from the rest of the wires... a white one, 2 yel/grn and one black... black is obviously a ground...
from my findings... all of the orange plugs are for abs... here are some... im guessing all the orange plugsa are for strictly abs... in that case i can get rid of those things in the first picture... am i correct
ok... next dilema... here i have 4 plugs from the passenger side in the front... off the main harness... (not the engine harness) the right one is the headlight... and the middle i am pretty sure is for the radiator fan... the two left plugs is what i cant figure out... i was looking at a friends gsr and it looks as if most go to something having to do with the a/c on the other side... they travel along the rad support... (the bigger plug) the plug (in case anyone wants to look at there car and figure it out) is right by the top of the radiator fan... the left side of it... and then the other plug just has two wires to it and it basically right by the bigger plug
here is one more pic of the two plugs i cant figure out
Old Jul 8, 2001 | 06:38 PM
bigTom's Avatar
Default Re: Wiring problems (4dr-gsr)
sorry... this is a 95 gsr harness
Old Jul 9, 2001 | 12:05 AM
PROFILES2000's Avatar
NICE HAND! you should consider modeling your hand!
Old Jul 9, 2001 | 08:06 AM
bigTom's Avatar
Default Re: Wiring problems (Y2kGsR)
Old Jul 9, 2001 | 10:15 AM
brinks's Avatar
LOL
Old Jul 9, 2001 | 10:16 AM
GQ 05YellowEVO8's Avatar
Default Re: Wiring problems (brinks)
Tom are you alive? I tried calling you over the weekend. I got a problem with my car. do you have any Spare MAP sensors lying around?
Old Jul 9, 2001 | 10:51 AM
bigTom's Avatar
Default Re: Wiring problems (VTEC-MAN95GSR)
yea... i saw the missed calls but i wasnt able to call back this weekend... i had so much stuff to do... yea... i have a map sensor... i could let u use it but i would need it back in a couple of weeks when my motor comes together...
ok... back to the subject... can anyone help me on the wiring... charlee... didnt u take out your abs? did u take the wires out as well?
egrunner
May 12, 2015 02:38 PM
Steeve_Civic
May 7, 2012 12:42 PM
10sec4door
Feb 11, 2010 08:41 AM
bigTom
Jul 11, 2001 02:34 PM
