5 Lug Conversion - Pros & Cons?
Old Aug 15, 2001 | 06:51 AM
OBD-One-Kanobe's Avatar
New User
Default 5 Lug Conversion - Pros & Cons?
What are your opinions on getting a 5 lug conversion?
Pros & Cons? Do you have to upgrade your brakes when you do this?
It seems like many production cars in the GS-R pricerange have 5 lug wheels but the Integra doesn't . . .
Anybody on the Integra board have this mod?
(ps - I'm just wanting some general info. I don't want to rice out my car so I can tell people it is a 4 door JDM type R )
- OBD-One-Kanobe -
Old Aug 15, 2001 | 07:05 AM
Smurf's Avatar
New User
Default Re: 5 Lug Conversion - Pros & Cons? (OBD-One-Kanobe)
I personally believe that the cost of the setup outweighs the advantages. If you are honestly looking to upgrade your brakes, you can order the same setup from fastbrakes in a 4lug setup. If you want the handling of an ITR, you can accomplish this with a well matched set of springs and shocks and sway bar.
So its really up to you where you wish to spend your money.
Old Aug 15, 2001 | 07:08 AM
nerdish's Avatar
Default Re: 5 Lug Conversion - Pros & Cons? (Smurf)
I think it's a cool thing to do, but generally a waste of money. Unless you have the perfect opportunity to change (ie: insurance) ..
To me, it's like a $700 valve cover. Not that extreme, but..
Old Aug 15, 2001 | 08:50 AM
2005 TSX's Avatar
Default Pros and cons?
Pro - You may have a wider selection or rims to choose from with a 5 lug conversion.
Pro - Educated people on Integras (especially those that critique every little picture put on this board) will notice your upgrade/conversion.
Pro - Always nice to be different.
Con - Could be expensive?
Con - Money spent on conversion will not affect overall performance of car.
Con - People may become "more interested" in your car.
Old Aug 15, 2001 | 09:27 AM
Mike K's Avatar
Default Re: Pros and cons? (2001 Integra GSR)
The brakes are awesome on 5 lug.
Also, stock ITR wheels look great.
But I agree, it is expensive.
Old Aug 15, 2001 | 10:38 AM
Mr. Choi's Avatar
New User
the only pros. on a 5 lug conversition is looks. braking or accerlation will still be the same as with 4 lug. its kinda hard to explaing why but you will have the same stopping distance with 4 lug vs. 5 lug. its also a big waste of money.
Old Aug 15, 2001 | 10:45 AM
bhcvc's Avatar
Just to add another Pro: having 5-lugs (vs. 4-lugs) better distributes the torque on the lugs and the wheel bearing so the bearing wears less. Not a very noticable effect, especially on the street, but a pro none-the-less.
Con would still be that it's an expensive endeavor.
Old Aug 15, 2001 | 11:19 PM
Rain_man's Avatar
New User
Default Re: Pros and cons? (bhcvc)
The extra lug is generally considered good because it can handle more horsepower. Each lug will have to deal with less force. Of course this is if you are making 300 hp and more on slicks.
Old Aug 16, 2001 | 06:58 AM
Big Teggie's Avatar
Default Re: Pros and cons? (Ein)
I heard that the itr 5lug weighs alot more than than gsr 4lug. Is that true?
Old Aug 16, 2001 | 07:11 AM
bigTom's Avatar
Default Re: Pros and cons? (Big Teggie)
it is heavier but... it also does make your stopping distance shorter... at least in my experience... the itr brakes are much better... to ad to it... another thing is it does look nice
but thats also a bad thing... i disagree that people MAY become more interested in your car... they WILL!
Old Aug 16, 2001 | 08:43 AM
2005 TSX's Avatar
Ok, so change may to will. I made it a con, because more attention is not always better. This is especially true for cars that already have a high theft rate.
[Modified by 2001 Integra GSR, 12:19 PM 8/16/2001]
Old Aug 16, 2001 | 09:05 AM
bigTom's Avatar
yea... its definately a con... id rather have a 4-lug that no one notices for that fact... cuz anyone thats knows their ****... and see's a 5-lug... means u have something under the hood as well... no one puts a 5-lug on just for looks...
but the breaking is far superior to the gsr
Old Aug 16, 2001 | 11:17 AM
2005 TSX's Avatar
How much better is the braking on a Type-R than a GSR?
[Modified by 2001 Integra GSR, 12:18 PM 8/16/2001]
Old Aug 16, 2001 | 01:01 PM
guyuenvy's Avatar
Pros: extra braking, cool 5 lug wheels only avaiable in 5 lug volk etc.. Teh looks from people seeing a 4 dr 5 lug
cons: expensive
Old Aug 16, 2001 | 01:20 PM
crookedletterd's Avatar
New User
Default Re: 5 Lug Conversion - Pros & Cons? (guyuenvy)
guyuenvy, your car is soooo sweet i saw it at import life episode 1. good work!
Old Aug 16, 2001 | 02:12 PM
DR. ON POINT's Avatar
Banned
y is one wheel white???
5 lug sucks for slicks
Old Aug 16, 2001 | 02:20 PM
GSRgrrl's Avatar
Default Re: 5 Lug Conversion - Pros & Cons? (On Point)
There a lot of reasons to do a 5 lug...yes, bigger brakes, but also better handling in the corners. The suspension is a whole lot stiffer, unlike the stock GS-R's.
I agree it also looks cool, but if you're not going to do it for the performance aspect, why bother.
Old Aug 16, 2001 | 03:00 PM
2005 TSX's Avatar
Default Pros & Cons?
5 Lug Conversion = Better handling?
How so? I am not quite sure that a 5 lug conversion means stiffer suspension. I could be wrong though.
Old Aug 16, 2001 | 03:05 PM
guyuenvy's Avatar
From my understanding the bushings on the suspension are stiffer and you can put the swaybar without problems making it stronger.
Old Aug 16, 2001 | 03:07 PM
Pat's Avatar
Pat
Default Re: Pros & Cons? (2001 Integra GSR)
how bout having to loosen/tighten 1 more lugnut per wheel? I'd say thats another con, although trivial...
Old Aug 16, 2001 | 03:15 PM
GSRgrrl's Avatar
If you're doing the 5 lug the right way, you get the complete suspension plus the bushings kit. I didn't do the 5 lug on my first car, a 90 integ, but I did the bushings. I could seriously take a corner rated for 35 way above 90...not that I tried of course! You could ram into the side of that car and it would NOT move.
Old Aug 17, 2001 | 03:03 PM
Nighthawk GS-R's Avatar
New User
cons: expensive
How much did that cost anyway? where did you get the parts from?
Old Aug 18, 2001 | 01:07 AM
keys's Avatar
Default Re: 5 Lug Conversion - Pros & Cons? (Nighthawk GS-R)
hye guyuenvy i like your car, but i'm not digging that white rim.... is this a new trend?
anyways, i heard from around my area that some hardcore racers with ITRs are doing 4 lug conversions because it's lighter... can anyone confirm this?
Old Aug 18, 2001 | 06:20 AM
Banned
Default Re: 5 Lug Conversion - Pros & Cons? (keys)
ohh sh t some hard core racers are doing 4 ;ug conversions we all better watch out on the streets
the diference in the 4 lug and 5 lug is about 5 ounces. there isnt a big weight difference. There are pros and cons on ths subject the question is it right for u. Personaly i wouldnt get it because i would like large slicks. If I didnt use slicks i would defenitly get it becasue it looks tight. The brakes are good but u could just upgrade 4 lug brakes. Oh well it all depends on u and what u like
Old Aug 18, 2001 | 11:17 AM
keys's Avatar
well if the difference is only 5 ounces then i guess those racers got duped into thinking they would get rid of a lot of weight by changing to 4 lug
