Speedbleeders
Old Aug 15, 2001 | 09:56 AM
Pat's Avatar
Pat
Default Speedbleeders
Any comments on this product's effectiveness and ease of installation? Any other comparable products at its price range worth considering? I might get a set to and put em in when I change brake fluids. TIA!
Old Aug 15, 2001 | 10:01 AM
dustin's Avatar
Default Re: Speedbleeders (Pat)
You can use those, or you can do what I did.
I went to a pet store and bought a $1.99 aquarium check valve. Then I got some vacuum hose I had laying around, and I put 6" or so on one side of the check valve (the IN side) and a couple feet on the other side (OUT). Then I just pushed the vacuum line over the stock bleeder screw and put the other end in a coffee can. Loosened the screw, and then I just pressurized the brakes/opened the screw repeatedly until there was no air in the lines.
Worked like a charm and only cost $1.99
Dustin
voithofer
Oct 7, 2019 02:57 PM
cheeesboiger
Jun 20, 2011 09:30 AM
Xscort
Feb 15, 2009 11:59 AM
djnikko
Nov 5, 2004 08:02 AM
nd8ch
Jan 12, 2004 11:12 PM
