help!!!!! w/ lca bolt
Old Aug 14, 2001 | 05:12 PM
b18bvudoo's Avatar
New User
Default help!!!!! w/ lca bolt
we got the nut off w/ the help of breaker bar, but bolt wont slide out...do you hammer it out??
Old Aug 14, 2001 | 05:25 PM
bikeboy80's Avatar
Default Re: help!!!!! w/ lca bolt (vudoo666)
yea all the bolts might have to be hammered out, you might have to use a small screwdrive to push them all the way through
[Modified by bikeboy80, 6:29 PM 8/14/2001]
Old Aug 14, 2001 | 05:32 PM
ALF's Avatar
ALF
Dam, you're lucky! When I tried to take mine off, I broke the heads of both of the bolts. Just take a screwdriver and hammer that bastard out.
Old Aug 14, 2001 | 05:56 PM
b18bvudoo's Avatar
New User
Default Re: help!!!!! w/ lca bolt (Dozed)
says in helms that they're self-locking bolts. can you hammer those out, cause it dont look like its budging w/ the hammer
Old Aug 14, 2001 | 06:24 PM
Chris's Avatar
use a jack to gently relieve the tension on the LCA (kinda lift it a hair) That might help.
Old Aug 14, 2001 | 08:03 PM
sgT's Avatar
sgT
I hope this is the front.
The rear nuts are welded onto the shock.
The rear bolts on old cars have a bad habit of siezing. usually requires the
replacement of the bushing or lca altogether.
Old Aug 14, 2001 | 08:18 PM
b18bvudoo's Avatar
New User
Default Re: help!!!!! w/ lca bolt (sgT)
well somehow we got the nut off the rear, but the bolt wont slide out, something about it being self-locking. the bolt further out on the lca wont budge either, might of stripped it, damn it. any help is appreciated; i think i might have to buy a drill and drill it out, which i've never done before either.
Old Aug 14, 2001 | 09:16 PM
bikeboy80's Avatar
well that sounds familar, if you end up destroying the bushings getting it out, buy a new lca with bushings already in it ($90) it will be cheeper that getting acura to press out the old bushings and put in the new ones, good luck
Old Aug 14, 2001 | 09:54 PM
b18bvudoo's Avatar
New User
Default Re: help!!!!! w/ lca bolt (bikeboy80)
i think i know why the bolt isnt coming out. whenever i try to turn it, the bolt seems to have a spring-back feel 'cause the bolt is somehow stuck to the lca bushings, damn. well i was liberal w/ the wd40 on the bushings and will try to get it out tomorrow.
you guys think silicon grease will help?? how bout air wrench??
btw, the nut IS welded to the struts in the rear but somehow we got it off...oh well i'll try to work w/ it. Btw i'm puttin in koni yellows w/ gc's.
Old Aug 14, 2001 | 11:21 PM
sgT's Avatar
sgT
replace the LCA.
cut the bolt on both sides so you can get the shock out and remove the LCA.
The bolt isnt self locking. Its made in a way thats not supposed to sieze.
Guess waht, it doesnt work that well. All old cars do this. Just hit up a junkyard
Old Aug 15, 2001 | 10:01 PM
b18bvudoo's Avatar
New User
well, about to assemble the koni yellow/gc combo. question: gc instructions say to cut the stock dust cover (which is metal), anyone have to do this? and according to gc instructions you dont use the rubber dust boot either.
civic46
Jan 19, 2009 05:53 AM
IAcivicEK
Jul 1, 2007 07:37 PM
EGhatch33
Suspension & Brakes
24
Jan 2, 2006 10:01 AM
gowyeng
Jun 20, 2004 12:02 AM
Integra_Nguyen
Aug 10, 2002 06:58 PM
