Timing belts Replacement???
Old Aug 14, 2001 | 12:19 PM
zojirushi's Avatar
Default Timing belts Replacement???
How much should I expect to pay to get my timing belts and other belts replaced? I have a 95 auto Integra LS.
Old Aug 14, 2001 | 02:38 PM
redline's Avatar
Default Re: Timing belts Replacement??? (zojirushi)
about 4-5 hours labor
Old Aug 16, 2001 | 04:49 AM
yaksplat's Avatar
Just do it Yourself. It was one of the first things i did after i bought my 94 gsr with 97245 miles already on it.
Old Aug 16, 2001 | 05:08 AM
DavidGSR's Avatar
The going rate at a shop is $400-$500. That should include water pump, accessory belts.
Old Aug 16, 2001 | 05:33 AM
DmanNYC2001's Avatar
New User
Do not over look this job!!!
90K max on first change. List of things to change as well..
Water pump & o-ring
timing belt tensioner & spring
replace all antifreeze with *ONLY* either; HONDA (blue-green), Toyota (Red) or
prestone long life phosphate free (Orange) antifreeze.
older (green) antifreeze was designed for detroit iron, not honda, toyota or nissan.
it *WILL* corrode the metals inside your engine as well as shrink the seals on the water pump. your engine will die a horrible death...
If your oil pan gasket is leaking, might as well change;
oil pan gasket
oil pump seals & gasket
pickup tube gasket & o-ring
If you have your own garage & tools, this is an easy job.
I waited til 97k and made it a difficult job + extra $$ for tow home.
Had to pull the head off & check 4 damage. I got lucky...
get a coupon in the mail and take it to the Acura dealer if you dont do it yourself.
$100 off timing belt maint... (i think the acura service interval includes timing belt + water pump)
cheap mechanics will only change the belt.
dumb mechanics wont install it properly or tension the belt.
Use OEM belt & waterpump. maybe sub belt if your parts dealer can get either nissin or gates belt.
do not sub the pump with non oem...
90R3x
Dec 5, 2016 02:09 AM
raverx3m
Dec 27, 2011 02:13 AM
Mike VR6
35
Mar 2, 2007 03:23 AM
jdmgeorge
Feb 18, 2004 12:45 PM
