test pipe with comptech header
Old Aug 16, 2001 | 11:46 AM
Rob Dizzle's Avatar
Default test pipe with comptech header
does a 2.5 inch test pipe (like GOD'S) work with comptech header and stock exhaust on a 95 gsr?
is it possible to just bolt off the test pipe, and also bolt on the cat when im not at the track?
Old Aug 16, 2001 | 12:04 PM
owen_the_soyboy's Avatar
Default Re: test pipe with comptech header (bob46802)
Revolutions [revolutions@ecol.net] has testpipes that are resonated, a cherry bomb really, with flanges already in the right spots and an O2 bung if your car needs one. They have them / make them for every teg model I think.
ready to bolt in and cheap too... not as cheap as GOD's but they do the trick and help the car sound a bit deeper. Here is a pic of one on my 94 GSR with Apexi header and N1 catback. I am VERY satisfied with the results, although they have only been tested on my butt-dyno. Sound wise there is a nice improvement in tone.
HTH.
Owen
Old Aug 16, 2001 | 12:06 PM
oh yeah, answers....
the well known 'GOD's testpipe' is designed to work with JDM sized collectors, hence the "2.5 inch" name.
You will not be able to use this on a non-2.5 inch collector/header.
Old Aug 16, 2001 | 12:11 PM
H23 Power's Avatar
comptech makes a test pipe...it would probably work pretty good with a comptech header
http://www.autocarparts.com
Old Aug 16, 2001 | 12:14 PM
DmanNYC2001's Avatar
New User
Default Re: test pipe with comptech header (owen_the_soyboy)
Do you have a problem with backfire?
Old Aug 16, 2001 | 12:22 PM
Default Re: test pipe with comptech header (DmanNYC2001)
backfire? hahahaaaaa, I WISH it would backfire!
I wish it would shoot 3 foot flames on downshifts too. I really do.
nope never does, sometimes it burps a bit, but that is very mild an dI have heard non-testpipe civics/tegs do that with aftermarket catbacks.
Old Aug 16, 2001 | 12:28 PM
New User
the first time I had a test pipe on my teg, I almost sh@t my drawers, it backfired so loud and I was on the highway going through an underpass. Damn, everyone was staring... I wonder if there were flames? Funny though only backfires on a 1-2 upshift. Weird man, just like the damn tranny would pop out of 2nd in a left hand curve.
Old Aug 16, 2001 | 01:30 PM
Rob Dizzle's Avatar
does anyone know for sure if the comptech will directly bolt on?
thanks
Old Aug 16, 2001 | 01:32 PM
H23 Power's Avatar
yes, it will
Old Aug 16, 2001 | 02:07 PM
1fastGSR's Avatar
New User
Default Re: test pipe with comptech header (01GSR)
I called Comptech today. They only have test pipes for 94-99 GSR. I wanted one, but mine is a 2000 so it's different.
I need some help! Would the check engine light come on with a test pipe? even if it has bung for the O2 sensor? how do you turn it off?
If heard of people say that there is NO gains with a test pipe?? Is that true? If not, what kinda of HP gains am I looking to get? Thanks
Old Aug 16, 2001 | 06:33 PM
Stephen's Avatar
Default Re: test pipe with comptech header (1fastGSR)
OBD2 (96+ or 97+, I can't remember) have a second O2 sensor. It is there to make sure that your cat is being used.
If you run a test pipe you will have a CEL.
One way around that is to have a sensor bung with a little bit of catalyst in it to "fool" the O2 sensor.
Tippyman
Dec 21, 2005 07:30 PM
SleepnCiViC
Nov 10, 2005 08:19 AM
willieB18C
Feb 11, 2005 11:36 AM
ludermark
Sep 14, 2004 09:07 PM
