mounting hardware for rear speakers?
when i got my integra, it didnt have any rear speakers. two days ago, i got some jbl gto 6.5's and installed them in the front and i was planning on putting the stock speakers in the rear. when i took off both rear side panels, i found that there were no mounting brackets for the speakers. correct me if i'm wrong, but there should be something there to mount the speakers on right? any suggestions on what i should do? if i gotta buy new ones, how much do they usually run and where can i get them? TIA.
*i know this is an audio topic, but i thought i might get a bit more info here.
Will you make something up for me please?
Re: mounting hardware for rear speakers? (LillDragun)
post a picture. i just installed my rears and there should be a black plastic piece that is back there.
Just go to Acura and buy a set, I'm sure they won't be more than $15. Good luck.
Re: mounting hardware for rear speakers? (shamoo)
You know, I have some speakers I bought for the front of my car.. just the door ones, 6.5's... now I went to install mine, took out the stock speakers and everything, but then came my problem... the wiring. Do I splice into the stock wiring to add the speaker wire that comes with the new speakers or no?? I do not wanna have to run all new wiring from the unit to the door, so what do I do??
Re: mounting hardware for rear speakers? (BranzLS)
you can buy a harness from circuit city. it has a connector that attaches to the stock speaker harness, and on the other end, has wires that connect to the aftermarket speaker. i'll post a pic of the harness when i find it.
Re: mounting hardware for rear speakers? (GSR44)
Dam really? It's like the aftermarket harness I used to connect my stereo to the stock wiring right?? I got that from Circuit City...... I'll have to check that out. Thanks
mr_mbuna
Audio / Security / Video
09-08-2002 12:45 PM
