Some Please explain Final drive?
Old Apr 22, 2002 | 03:02 PM
Nighthawk GS-R's Avatar
New User
Default Some Please explain Final drive?
ok what i thought it was its not...so what exactly is it?
thanks in advance
Old Apr 22, 2002 | 03:57 PM
Weston's Avatar
Default Re: Some Please explain Final drive? (Nighthawk GS-R)
I beleive the final drive is the gear inside the differential. If your 1st gear ratio is 3.23 and your final drive is 4.40, then the actual ratio between the engine and the wheels is 14.212. The GS-R and LS have the same 1st and 2nd gear ratios, but the LS has a longer final drive (a little under the GS-R's 4.40), so the LS effectively has longer 1st and 2nd gears. A lower number for the gear ratio indicates a longer gear, because it takes less rotations of the engine to produce one rotation of the wheels. Longer gearing will give you a higher top speed, but shorter gearing will give you better acceleration.
Midori Green
Apr 30, 2008 09:11 PM
5zigen_dc5
Mar 31, 2006 05:06 PM
swrdply400mrelay
Dec 18, 2002 04:06 PM
Dorikamu
Jun 20, 2002 11:39 AM
bocian
Apr 16, 2002 08:58 PM
