Help with clutch...
Old Apr 20, 2002 | 05:41 PM
araknis's Avatar
New User
Default Help with clutch...
I just a header installed on my '95 GS-R and during the process the mechanic removed something to do with the clutch to give more room in putting in the header. Now I'm having a problem with a loose clutch. Usually there will be resistence when it's depressed maybe 15% or so, but now i press maybe 70% before I begin to feel resistence. I looked under my hood and I think it might be my fluid. Is the smallest resevoir the clutch fluid?
Old Apr 20, 2002 | 07:05 PM
Jubba's Avatar
Default Re: Help with clutch... (araknis)
your bleeder valve is right there between the header your fans. i took mine out when i installed mine. you need to get all the air out of the lines and put some more fluid in. you can do it yourself, but i reccomend you buy a helms or haynes manual. if you have trouble you can mail me at ackjoshypoo@aol.com and i can try to help you out.
Old Apr 20, 2002 | 10:18 PM
kkim's Avatar
sounds like you got some air in the clutch hydralic system. yes the small resevoir is the clutch fluid, but why don't you just take it back to the mechanic that did the work and have him fix the problem he caused?
diviznrider
Feb 4, 2011 11:01 AM
Bserieskiller
Feb 17, 2006 05:52 PM
el_dave_o
Sep 30, 2005 04:05 AM
type_sml
Aug 23, 2002 12:53 PM
VTEConly
Apr 28, 2002 03:11 AM
