Difference between 4x100 and 4x114.3?
Old Apr 21, 2002 | 03:37 PM
Calavera's Avatar
Default Difference between 4x100 and 4x114.3?
A x B
'A' refers to the number of bolts and 'B' refers to what? The length of the bolts???
Why would someone pick 4x100 or 4x114.3 over the other? Does the offset influence any of these?
TIA.
Btw, does this belong in the newbie forum?
Old Apr 21, 2002 | 03:39 PM
teg92's Avatar
Default Re: Difference between 4x100 and 4x114.3? (Calavera)
Distance between diagnol.
GS-R_nut's Avatar
14.3...........
sorry dont know exactly...
Old Apr 21, 2002 | 04:40 PM
Calavera's Avatar
Default Re: Difference between 4x100 and 4x114.3? (GS-R_nut)
Oh I see, it's the distance between two diagnal bolts....thanx.
[Modified by Calavera, 5:42 PM 4/21/2002]
Old Apr 21, 2002 | 04:43 PM
fiebru1119's Avatar
H-T correct me if im wrong but i think its this:
o o
o o
on some cars the distance of the diagonals is 100mm. on others its 114.3mm
Old Apr 21, 2002 | 08:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Difference between 4x100 and 4x114.3? (fiebru1119)
It's actually the diameter of a circle drawn through all the bolts (you can't measure diagonal distance on 5-lug hubs, it's a circle drawn through the bolts). 4x114.3 (4x4.5") has a larger circle than 4x100.
Old Apr 21, 2002 | 08:42 PM
Calavera's Avatar
Default Re: Difference between 4x100 and 4x114.3? (PatrickGSR94)
Thanx for clearing that up.
Old Apr 22, 2002 | 07:02 AM
Project X's Avatar
Here's a good info.
http://www.tirerack.com/wheels/tech/boltpatt.htm
Old Apr 22, 2002 | 05:29 PM
GSRaCeRbOI's Avatar
its the diameter of a circle around the centers of all 4 bolts... you would pick 4 x 100 or 4 x 114.3 or whateever depending on what kind of car you have unless you change the hub and bolt pattern or sumthing.. haha so its pretty much static... the offset doesnt influence the bolt pattern or vice versa.. the offset is how much off center (either + or -) from the center of the rim and the hub...
civics and integras are 4 x 100
and the older accords and preludes that had 4 lugs are 4 x 114.3
Old Apr 22, 2002 | 06:27 PM
D.Lansing's Avatar
Default Re: Difference between 4x100 and 4x114.3? (GSRaCeRbOI)
the early ITRs are also 4X114.3
triumph_013
Jul 16, 2010 10:07 PM
victor.m
16
Mar 13, 2008 05:51 PM
tmramsburg
Jun 17, 2007 06:26 AM
integration
Jan 6, 2003 08:13 AM
SiRkid
Oct 7, 2002 11:21 AM
