engine swap question . . .
Old Apr 23, 2002 | 08:54 AM
egNdc's Avatar
Default engine swap question . . .
How easy, or how hard would it be to fit a 2000 DX hatchback engine into a '97 Acura Integra GSR? I need an engine for about a month and a half while my engine is getting built, and I have an extra DX motor at my house I want to use. What if any extra parts would I have to purchase in order to make this work? Any suggestions would be great...thanx in advance.
Old Apr 23, 2002 | 08:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: engine swap question . . . (egNdc)
Both are OBD2 so that's good. You might get CEL's since the motor is not VTEC-equipped, unless you also have a DX computer to use.
Old Apr 23, 2002 | 09:07 AM
egNdc's Avatar
Default Re: engine swap question . . . (PatrickGSR94)
I have everything...from the computer to the mounts to the shift linkage to the axles...EVERYTHING...think I will run into any problems, or should it bolt right in??? thanx again
Old Apr 23, 2002 | 10:48 AM
jermothedrunk's Avatar
i can tell you right now if you dont have the motor mounts for the civic motor you need to get them before you can do that swap. the integra and civic motors have completely different motor mounts.
Old Apr 23, 2002 | 10:50 AM
Default Re: engine swap question . . . (jermothedrunk)
sorry just read that you had the mounts for the civic engine so it should just fit right in. there will always be little things that go wrong involved but they should be very minor.
90efSI
Jul 30, 2006 10:57 PM
Jeff
May 9, 2005 09:46 AM
SystemAddict
20
May 1, 2002 01:46 PM
egNdc
Apr 23, 2002 02:53 PM
LshatchTurbo
Oct 18, 2001 04:21 PM
