need help with an engine problem
Old Apr 21, 2002 | 05:15 PM
subtleluck's Avatar
Default need help with an engine problem
i got a 97 gs-r and well basically in the interval between 3 and 4 thousand rpm it sounds like a very mild version of gears grinding...(noise also occurs when i just rev up in neutral) this only happens after driving for a while though...if i let the car cool .and then drive again...noise goes away temporarily, but the heat gauge shows normal all the time (so, no overheating).. i haven't changed the oil in about 3k miles, but the manual says change every 3500miles so that can't be it, engine sounds nice untill 3k...then the vrooom turns into grrrrrr, then at 4k everything goes back to normal..and i get a really nice VROOM...all the way till redline. any ideas on what is wrong w/ my car? i just noticed this happening recently... i'm HOPING an oil change is all i need ... i herd great things about gs-r engines...i'd hate to be the one w/ the gs-r that fucked up.
thanx for the help guys
Old Apr 21, 2002 | 05:16 PM
dubster99's Avatar
Default Re: need help with an engine problem (subtleluck)
If it's a rattling noise, check your heat shields. They have a tendency to rattle between 3500-4000 rpm.
Old Apr 21, 2002 | 05:33 PM
subtleluck's Avatar
Default Re: need help with an engine problem (dubster99)
that's exactly it it's an annoying rattling noise that kicks in around 3500rpm... i'll check the heat sheilds first thing tommorrow morning...i hope ur right. then i can just tighten the bolts and problem solved?
thanx dubster99
Old Apr 22, 2002 | 11:31 AM
GreenD's Avatar
dont worry, its a vibration in the a-pipe off the exhaust manifold. this is a very common problen in some gsr's that acura refused to recall. i had the exact same problem with my 97 gsr. instead of wasting your time/money trying to fix it, this is a perfect excuse for u to get a header!!
also, tightening the bolts wont do any thing because its coming from one of the secondary pipes.
SmellsLikeMustand
Aug 10, 2009 10:14 PM
revhardEK
Jan 25, 2008 06:05 PM
gsrpwr
Aug 25, 2004 09:08 AM
all420
Sep 29, 2002 11:41 AM
