squishy brakes
Old May 20, 2003 | 05:13 PM
natrl's Avatar
Default squishy brakes ( REVISIED - AT BOTTOM OF PAGE )
when i apply the brakes, the brake pedal gives.... im able to push the pedal all way down and the doesnt slow down the car as good...im thinking that might be a leak somewhere...please help
Modified by natrl at 6:58 AM 5/22/2003
Old May 20, 2003 | 05:20 PM
Turbo Powa's Avatar
Default Re: squishy brakes (natrl)
either a leak or these is air in the brake system. Bleed the brakes and see how it turns out.
Old May 20, 2003 | 05:25 PM
97hb's Avatar
Could also be your brake fluid cap.
Old May 21, 2003 | 05:57 AM
IntEGNYC's Avatar
Default Re: squishy brakes (97hb)
bleed your brakes.
Old May 21, 2003 | 06:00 AM
ragejed's Avatar
Default Re: squishy brakes (IntEGNYC)
when u bleed them...after you do them the first time , tap the caliper with like a wrench. dont smack it tho, lol. this is dislodge any air trapped.
I bled mine, then had to take off the caliper, then put it back on, bled again, and a huge *** fart came outa it solved my squishy brakes tho, lol
Old May 21, 2003 | 02:19 PM
Turbo Powa's Avatar
Default Re: squishy brakes (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">
I bled mine, then had to take off the caliper, then put it back on, bled again, and a huge *** fart came outa it solved my squishy brakes tho, lol</TD></TR></TABLE>
LMAO!!!
Old May 21, 2003 | 02:32 PM
cjn's Avatar
cjn
Default Re: squishy brakes (Panda EK)
Yes, hit your calipers with a rubber mallet or hammer. It works well to get the air bubbles out of the calipers.
I do this at the track and it works wonders.
If bleeding your brakes doesn't fix the problem, I'd suspect your master cylinder may be failing. But that is a long shot.....
Good luck.
Old May 21, 2003 | 06:37 PM
red alert's Avatar
Default Re: squishy brakes (Burninator)
well maybe your master cylinder is going out. had the same problem in my 92 teg
1999 gs-r
Old May 21, 2003 | 08:29 PM
romeo619romeo's Avatar
Default Re: squishy brakes (red alert)
usually its not the master cylinder thats going out. usually the propotioning valve does.. if not that.. your lines might be flxing too much or.. theres water in yhe system/and air bubbles.. try to flush and bleed correctly..
Old May 21, 2003 | 08:31 PM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda EK &raquo;</TD></TR><TR><TD CLASS="quote">either a leak or there is air in the brake system. Bleed the brakes and see how it turns out.</TD></TR></TABLE>
Let us know how it turns out after you bleed/flush your brake fluid.
Old May 21, 2003 | 08:40 PM
B2FiNiTY's Avatar
Definately could be the brake master cyclinder but bleed the brakes first.
Old May 21, 2003 | 09:02 PM
natrl's Avatar
Default Re: squishy brakes (B2FiNiTY)
THANKS EVERYONE...but i forgot to mention more piece of info that might help....i noticed that again today it happened during the day (HOT DAY) and when it was REALLY hot in the engine bay...and when i let the engine cool down...the brakes seem to work fine and even at night...i hope this helps to narrow down on the problem...thanks again
Old May 21, 2003 | 09:24 PM
Bill Hook's Avatar
Hot = expansion?
Would high temps cause bubbles in the lines to expand?
Old May 22, 2003 | 05:10 AM
96IntegraLS4DR's Avatar
I suggest you do the easier and cheaper thing first- bleed your brake.
IF that doesn't solve your problem, then replace brake MC.
Old May 22, 2003 | 09:05 AM
JimBlake's Avatar
Default Re: squishy brakes (96IntegraLS4DR)
Since it happens when it gets hot, I think it's more likely that you need a new MC. Yes, high temperature makes the bubbles expand, but they'll still be squishy when it's cold.
One subtle difference... If you have air in the lines, the pedal will be mushy when you first press on it; then get hard if you pump it. If your MC is bypassing, the pedal will be hard at first; then if you continue to press the brake (not real hard) it'll sink to the floor.
Are you gonna bleed them yourself or take to a mechanic?
If you DIY, then bleed them first, because that's cheap & easy. Just in case that fixes it. If you go to a mechanic you're gonna pay more than just a couple bucks for the fluid. Decide for yourself.
Old May 23, 2003 | 04:13 PM
natrl's Avatar
Default Re: squishy brakes (JimBlake)
i was thinking of bleading them myself...but i need to look for direction on how do do it...any websites u recomend??
austinkli
23
Oct 31, 2008 06:26 AM
whitehf
May 29, 2006 10:00 AM
zcivicz
Apr 8, 2005 07:40 PM
bOOsTiNSoHcVtEc
May 11, 2004 12:55 PM
Mike_C
Apr 1, 2004 11:18 AM
