oem piston ring gap
Old May 16, 2003 | 07:50 PM
itsalan's Avatar
Default oem piston ring gap
oem gsr pistons and rings...stock bore...what should the ring gap be? thanks
Old May 16, 2003 | 09:39 PM
itsalan's Avatar
Default Re: oem piston ring gap (alan909)
anyone?? please??
and yes i did use the search, however there weren't any specs for oem rings, just arias and endyn so any help i can get is appreciated, thanks
Old May 16, 2003 | 10:44 PM
IN VTEC's Avatar
For new rings
Top ring - .20mm - .35mm (.008" - .014")
2nd ring - .40mm - .55mm (.016" - .022")
Oil ring - .20mm - .50mm (.008" - .020")
Service limits:
Top - .60mm (.024")
2nd - .70mm (.028")
Oil - .70mm (.028")
You don't wanna use the serivce limit specs for new rings. If they're higher than new spec, then you need another set of rings or an overbore with oversized rings. If the gaps are too small, you need to file down one end squarely until it comes into spec.
Make sure that when you check the ring end gap that the ring is square with the cylinder wall. If it's not, then the ring won't be compressed enough and you'll read it as being too wide.
Old May 17, 2003 | 01:33 AM
tC_Dragon's Avatar
Default Re: oem piston ring gap (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">For new rings
Service limits:
Top - .60mm (.024")
2nd - .70mm (.028")
Oil - .70mm (.028")
wow... now i kno who to go to for my tech questions...
Old May 17, 2003 | 02:22 AM
itsalan's Avatar
thanks, big help
Blake St.romain
Aug 26, 2018 08:34 PM
energ3tic2
Jun 25, 2012 07:14 PM
jetpilot
10
Apr 28, 2005 09:22 PM
PHiZ
Jun 9, 2004 06:01 PM
Super_Eg6
Mar 26, 2004 10:27 AM
