Clutch Problems
Old May 20, 2003 | 11:29 AM
suavea82's Avatar
Default Clutch Problems
I have a factory clutch on my 94 ls. All of a sudden there is barely any pressure on my clutch. Does anybody know why?-do I have to bleed the slave cylinder? Thanks
Old May 20, 2003 | 11:50 AM
WiggiE's Avatar
New User
Default Re: Clutch Problems (suavea82)
It sounds like your master or slave cylinder just went out.
Check around the clutch pedal on the inside of the car, for leaking fluid. Check around the slave cylinder (on the tranny) for leaking fluid. Check the amount of fluid in the reservoir.
Old May 20, 2003 | 12:06 PM
suavea82's Avatar
Default Re: Clutch Problems (WiggiE)
I'm sure I sound retarded, but where is the reservoir for the tranny fluid?-that may be my problem since I have alway thought that motor oil ran through the manual tranmission. I have never been able to find a reservoir/dipstick for the transmission. thanks for you help
Old May 20, 2003 | 01:27 PM
JimBlake's Avatar
He means the reservoir for clutch hydraulic fluid. Outboard from the brake master cylinder, similar but smaller. You might just need to bleed the air out of the clutch line. But if there's any leaks, or if bleeding doesn't fix your problem, then you need a clutch master or slave, or both.
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
fcjohnny
Nov 19, 2009 07:33 PM
dgerej2
Oct 1, 2009 07:16 AM
Gomdohree
Apr 24, 2008 06:20 AM
malubawla
Oct 16, 2005 04:16 PM
