First upgrade on integra
Old May 17, 2003 | 12:49 PM
bradester's Avatar
Default First upgrade on integra
what should be my first mod for my car? suspension? or engine swap (talking about an integra RS 90-93)
Old May 17, 2003 | 01:05 PM
Audio28's Avatar
Default Re: First upgrade on integra (bradester)
intake from ebay
Old May 17, 2003 | 01:08 PM
neo1z's Avatar
Default Re: First upgrade on integra (Audio28)
Whats the budget? How many miles on that motor? I mean if the motor is on its last leg id consider getting another one prior to anything else. If you want to keep that motor - then I would do suspension first.
Old May 17, 2003 | 01:16 PM
JDC2's Avatar
Default Re: First upgrade on integra (neo1z)
i say suspension. its the best mod for street use and plus it makes your car look better.
Old May 17, 2003 | 01:29 PM
WiggiE's Avatar
New User
A good tune up should always be your first mod.
Old May 17, 2003 | 01:34 PM
MR. ARIZONA's Avatar
Default Re: First upgrade on integra (WiggiE)
I say suspension also. Coilovers, shocks, sway bars, camber kit, etc...
Old May 17, 2003 | 01:44 PM
caliquick_teg's Avatar
Suspention.
Old May 17, 2003 | 02:02 PM
riceball777's Avatar
if your car is 100% stock your first upgrade should be a $30 intake from e bay then after that shocks and springs
Old May 17, 2003 | 02:14 PM
lshobo's Avatar
Default Re: First upgrade on integra (riceball777)
air spencer air freshener.. after that, the sky's the limit
Old May 17, 2003 | 02:22 PM
B00ST2nR's Avatar
Default Re: First upgrade on integra (lshobo)
good tires maybe?
Old May 17, 2003 | 04:30 PM
mey_xanng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">A good tune up should always be your first mod. </TD></TR></TABLE>
Old May 17, 2003 | 04:55 PM
Sportmode's Avatar
i say get a good intake, then suspension. Lowering your car does make it look better but getting an intake will make it sound much better
Old May 17, 2003 | 05:01 PM
Typiko512's Avatar
if it's a used car, I'd say a major tune up. Just to make sure the car will be stable for the next couple thousand miles before you started to mod it. when u have the money or already have, then suspension/tires. get control of ur car before u go fast besides, it's the tires and the suspension that holds ur car not the turbo nor the kragen intake pipe.
Old May 17, 2003 | 06:37 PM
t72's Avatar
t72
Default Re: First upgrade on integra (Typiko512)
agreed.
tune up...
suspension/tires [camber kit]
then decide what will be your goal? low/mid or high end power?
Old May 17, 2003 | 06:55 PM
AllmotorJunkie's Avatar
INtake!
Old May 17, 2003 | 07:00 PM
NA gs-R 05 C
Guest
Posts: n/a
suspension.
Old May 17, 2003 | 07:17 PM
Danger's Avatar
Default Re: First upgrade on integra (NA gs-R 05 C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA gs-R 05 C &raquo;</TD></TR><TR><TD CLASS="quote">suspension. </TD></TR></TABLE>
Old May 17, 2003 | 07:23 PM
Lord Helmet's Avatar
I agree
Old May 17, 2003 | 07:30 PM
sExy_TinKY's Avatar
Default Re: First upgrade on integra (JonnyDanger)
i also say suspension...my $.02
Old May 19, 2003 | 06:07 AM
bradester's Avatar
Default Re: First upgrade on integra (sExy_TinKY)
I'll probably get the tune up first, but this is a new car i'm getting within a month and a half, but i'll probably get it checked out, then get suspension and then decide if I want to swap the engine or not. But if I do, is a JDM b16a good for a turbo?? cuz I know it just fits in the RS integra..but would ya'll put a turbo on it??
Old May 19, 2003 | 06:13 AM
TegLove's Avatar
intake, header, exhaust......sound better anyway..
Old May 19, 2003 | 06:20 AM
LSvtec03's Avatar
geez, if an engine swap is one of your options for a first mod, id go with that
Old May 19, 2003 | 06:56 AM
SIK IN DA HED's Avatar
New User
coilovers! drop that mug!
Old May 19, 2003 | 07:04 AM
bradester's Avatar
Would ya'll put a turbo on the jfm b16a tho? or just go all motor on that engine
Old May 19, 2003 | 08:05 AM
WiggiE's Avatar
New User
Default Re: (bradester)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradester &raquo;</TD></TR><TR><TD CLASS="quote">Would ya'll put a turbo on the jfm b16a tho? or just go all motor on that engine</TD></TR></TABLE>
They'll both work good. It all depends on personally preference.
If you have the money for a B16 swap and a turbo setup, you may want to consider dropping a bigger motor in there (i.e. B18xx, B20). That way you'll have alot of room to work with later on.
