Just did a compression test
Old May 18, 2003 | 03:55 PM
MachAF's Avatar
Default Just did a compression test
I did a compression test and got 230psi across the board. Its a b18c1 motor wuth 70k on it.
I see in helms it says 270psi is nominal.
What are you guys with b18c1 motors getting?
Modified by MachAF at 10:33 PM 5/18/2003
Old May 18, 2003 | 04:08 PM
CNSK's Avatar
Default Re: Just did a compression test (MachAF)
225 across cept cylinder 4....did 195...
Old May 18, 2003 | 06:43 PM
B U N M A N G O's Avatar
230's across the board is great... do a search, most of the guys are coming in between 210 and 225 or so.
Old May 18, 2003 | 06:47 PM
theman-dlh's Avatar
Default Re: Just did a compression test (bunmango)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bunmango &raquo;</TD></TR><TR><TD CLASS="quote">230's across the board is great... do a search, most of the guys are coming in between 210 and 225 or so.</TD></TR></TABLE>
230 is good compared to most i've seen, but if 230 is so good why does the Helm manual say 270 is normal.
just a ?
Old May 18, 2003 | 06:59 PM
neo1z's Avatar
Default Re: Just did a compression test (theman-dlh)
Its all dependant upon the tester you use -- Im sure its not identical to the tester Honda uses. 230 is awesome
Old May 18, 2003 | 07:30 PM
DR3AM's Avatar
Not only are you looking for higher numbers, but you're also hoping that the cylinders share close to or similar readings.
230 is damn good. My compression results for my '98 GSR with 118,xxx miles was (from Cylinder #1-#4) 205, 195, 190, 205. They're lower than yours but still within the normal specs.
Old May 18, 2003 | 08:13 PM
MachAF's Avatar
Default Re: Just did a compression test (Gizzzer98)
I just did my sisters GSR with 80k. Her's were 240 except the 3rd clyinder was 230.
infamouskillas
Jun 9, 2008 09:26 PM
dbiker207
Nov 26, 2006 07:10 AM
snowblind7x
Apr 13, 2005 08:12 PM
tweekerz
Apr 30, 2004 09:43 AM
Egone
Sep 5, 2003 09:41 PM
