5 lug question.
Old May 17, 2003 | 01:45 AM
Sukebei Oni's Avatar
Default 5 lug question.
i was thinking of doing a 5 lug conversion on my 96 4dr and since i already have an aftermarket coilover suspension, will i need to buy a new suspension to go with the Type R 5 lug conversion, or does the conversion just change the brake components?
i have search, but still unsure
Old May 17, 2003 | 02:00 AM
tC_Dragon's Avatar
Default Re: 5 lug question. (Sukebei Oni)
i believe the change over consists of more than just the brake components... Cuz all the companies have different susp. components for the R. or am i wrong?
Old May 17, 2003 | 02:06 AM
GoldenONE's Avatar
Default Re: 5 lug question. (pdcdragon)
if u use your stock lower control arms then you can use the suspension you have now but if u use the itr lca, then u have to the itr suspension
Old May 17, 2003 | 02:12 AM
Default Re: 5 lug question. (D Spec Dc2)
can i use my stock LCA and still have the 5 lug work, or is the type R 5 lug not compatible with my GSR LCA. cause i would like to get the OEM 5 lug wheels to fit on my GSR.
Old May 17, 2003 | 12:24 PM
ttt
Old May 17, 2003 | 12:36 PM
GoldenONE's Avatar
yes u can use your gsr lca and still do the 5 lug conversion...everything bolts up without any problems...i did it on my car so u shouldnt worry
Old May 17, 2003 | 12:51 PM
thanks
discman
Mar 13, 2008 01:19 PM
milligan41088
Jul 5, 2006 07:13 PM
mrEM1
Suspension & Brakes
Sep 13, 2005 07:46 AM
ki3t
13
Jul 31, 2003 12:20 PM
StinkyTofu
Nov 15, 2001 10:36 PM
