flywheels
Old May 18, 2003 | 09:19 PM
FastSS's Avatar
Default flywheels
Im either going to run an XACT prolite or streetlite, someone mentioned that the lighter flywheel will hurt my mid/low range power
I tried running a search but didnt find an answer I thought truely fit my question... so basically, what does flywheel weight have to do with power output and what will that weight difference do to my torque/hp curves?
Keep in mind that the prolite is 8.8lbs and the streetlite is 12.5lbs
Old May 18, 2003 | 10:01 PM
B16OnTop's Avatar
go with the Fidanza 7.5 lb flywheel a friend of mine has it and he has no problems with loss of HP or torque
Old May 19, 2003 | 05:09 AM
JCushing's Avatar
Default Re: flywheels (FastSS)
i got the prolite 8lb... it was cheaper than the aluminum ones and its chromoly so it wont warp. didnt notice any loss of low end at all. in my opinion if you want a 12lb FW you could just machine a stock FW. ive driven 3 cars not with FW's 8lbs or less and i see no reason not to have the lighter one. the 12lb might give you better launches (from what im told) as it will store more potential energy
Old May 19, 2003 | 08:18 AM
FastSS's Avatar
Default Re: flywheels (JCushing)
mmm that settles it then, 8.8 prolite it is
thanks for the advice
92B20VTEC
Jul 18, 2009 09:26 AM
Tyte-S
Oct 31, 2007 07:34 AM
Dj Skidz7
Apr 26, 2006 03:23 AM
djsin
Mar 31, 2005 05:15 PM
mattL
Apr 19, 2002 05:40 PM
