HELP: ignition timing
Old Jul 17, 2003 | 12:53 PM
integrasi's Avatar
Default HELP: ignition timing
okay, i just did whole bunch of research and it's confusing the hell out of me. currently i own 98 b18c (obdII). i just did a ignition timing and my car is lined up with red line. i read haynes manual & came with pretty much nothing, but they did had diagram showning crank pulley is line up with red line, also shown white line is TDC. so i went over to inlinefour asked someone, where i should line up and he told me i should line up with white line. by then i was so confused, i called up acura service, and he was telling me try both. hahaha anyhow would please someone correct me.
Old Jul 17, 2003 | 01:05 PM
fuck honda-tech's Avatar
Default Re: HELP: ignition timing (integrasi)
mines fine 18 degrees on the white line
Old Jul 17, 2003 | 03:54 PM
Comp97GSR's Avatar
Default Re: HELP: ignition timing (circuitgsR)
Dude, it depends on your timing gun. If it is NON adjustable, you can only check to see if your timing is within spec. (use one of the 3 timing marks) If your gun is adjustable (It will have a dial), use the white TDC mark and you read the dial on the gun to determine what your timing is at.
Old Jul 17, 2003 | 04:56 PM
t's Avatar
t
TDC-> White line (valve adj., etc.)
Timing-> Red line (16 deg. before TDC)
You should be able to figure it out from there.
Old Jul 17, 2003 | 06:55 PM
ED8DX's Avatar
Default Re: (t)
the lines are like this
front of car----> to firewall on the pulley.
white-red-white-space of no marks--white
white/red/white(all timing marks)---------Last white line is tdc.
make sure it is somewhere in the group of three, 18 deg,16 deg, 14deg (I believe the specs are correct)
Old Jul 17, 2003 | 09:03 PM
integrasi's Avatar
Default Re: (ED8DX)
so my timing should like up red???
Old Jul 18, 2003 | 12:47 AM
integrasi's Avatar
Default Re: (integrasi)
bump for help
Old Jul 18, 2003 | 01:36 PM
Comp97GSR's Avatar
First white line= 14*, red line= 16*, Second white line= 18*
or if you need more ignition timing you can use the TDC mark and use an adjustable timing light.
Old Jul 18, 2003 | 03:33 PM
t's Avatar
t
I could be wrong, but I dont remember 14 or 18 as being white (just notches on the pulley)Only white mark is TDC.
Old Jul 18, 2003 | 03:37 PM
DEVIN22CBR's Avatar
Default Re: (t)
red line is 18 º ...wammmoooo charles
Old Jul 18, 2003 | 09:09 PM
Comp97GSR's Avatar
Default Re: (BALL BAG)
Mine are white, but the dealer may have highlighted them.?.
Old Jul 19, 2003 | 12:21 AM
integrasi's Avatar
Default Re: (Comp97GSR)
okay, let's straight this up. it needs to be line up at 16+/-2 btc. so it's should be at red line.
Old Jul 19, 2003 | 05:54 AM
Vu's Avatar
Vu
16 is factory spec. +/- 2 degrees is within factory spec.
Old Jul 23, 2003 | 07:34 AM
SMC Integra's Avatar
Default Re: (Vu)
correct me if im wrong, but doesn' t the computer reset the timing to factory specs even if you try and advance it at all. So once you get the timing marks lined up, when you start the car, it will time itself.
Is this correct?
Old Jul 23, 2003 | 08:11 AM
StyleTEG's Avatar
Default Re: (SMC Rice Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMC Rice Rocket &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong, but doesn' t the computer reset the timing to factory specs even if you try and advance it at all. So once you get the timing marks lined up, when you start the car, it will time itself.
Is this correct?</TD></TR></TABLE>
You need to jumper the ECU with a paperclip when adjusting your timming to prevent this.
Old Jul 23, 2003 | 03:01 PM
Comp97GSR's Avatar
........ and it depends what year (obd?) you have. I know a friend that had a 2000 Si advanced his timing to 18', later after hooking up a diagnostic computer to it, it backed off the timing to 16'.
Old Jul 23, 2003 | 03:48 PM
integrasi's Avatar
it should be 16+/-2, so 18btc is okay
Old Jul 23, 2003 | 04:26 PM
Comp97GSR's Avatar
you are correct.
1990civicdx
Jul 17, 2018 06:13 PM
jakscivic
Mar 5, 2006 07:23 PM
sohc-8
Dec 26, 2005 04:19 PM
88da3
May 15, 2005 10:40 PM
