Quick Header install question!
Old Jul 19, 2003 | 12:52 AM
B18CYAAA's Avatar
Default Quick Header install question!
I am installing my header this weekend. Do I need a torque wrench to do this? Also, can I get some new gaskets at pep boy's or autozone, or will I have to get them somewhere else? Some help would be appreciated. Thanks.
Old Jul 19, 2003 | 08:59 AM
Padawan's Avatar
Darth ModerVader
Default Re: Quick Header install question! (B18CYAAA)
The bolts/nuts at the head should be torqued to 23 ft-lbs. As for the gasket, I've reused both and had no problem, but I usually prefer to at least replace the donut gasket. A Honda or Acura dealer should both the manifold and donut gaskets.
Old Jul 19, 2003 | 09:05 AM
DEVIN22CBR's Avatar
Default Re: Quick Header install question! (Padawan)
Mr. Gasket makes a copper exhaust manifold gasket which is suppose to seal really good but, If you are low on cash just re-use your stock gasket. I've never torqued them down. I just snug them down then turn a 1/4 turn .
Old Jul 19, 2003 | 09:57 AM
neo1z's Avatar
I really wouldnt say you need to have a torque wrench either. I just torque em down pretty tight, not overly tight, and I havent had problems or anything for 2 years. I wouldnt say a torque wrench is really detrimental.
Old Jul 21, 2003 | 02:25 PM
B18CYAAA's Avatar
Default Re: Quick Header install question! (neo1z)
Thanks for the help guys!
busyychild
Jan 28, 2018 07:52 PM
ERIC!
Aug 13, 2005 05:11 PM
r0cket247
Jan 15, 2004 04:21 PM
b16a1civichb
Nov 30, 2002 07:49 PM
vtecdc2
May 29, 2002 05:30 AM
