obd1
Old Jul 17, 2003 | 10:12 PM
F00LI0's Avatar
Default obd1
can anyone tell me what i need to convert my 00' gsr to obd1.
p.s. dont be a **** talker if i dont know as much as you
Old Jul 17, 2003 | 10:29 PM
Loveless's Avatar
Default Re: obd1 (F00LI0)
just the obd1 ecu (100~200) and the obd2 to obd1 harness (100~150)
btw, you did not search
Old Jul 17, 2003 | 10:38 PM
F00LI0's Avatar
Default Re: obd1 (Loveless)
thanks, yeah i should of searched
Old Jul 17, 2003 | 10:46 PM
4DooRGiSzer's Avatar
yea SKUNK2 has the harness. the shop around my area sells it for like 220. Then i would suggest also getting the ECU chipped at the same time. Make sure you get a rev limiter that is less then nine grand. my friend did the same thing as you, he missed shifted once or twice, and the needle went to 9500, on a stock internally engine, just have to be careful i guess, that is a future mod myself, but im going to get the SKUNK2 computer instead of buying a 94-95 teg ECU and chipping that.
Old Jul 17, 2003 | 11:00 PM
p1ccoloz's Avatar
OBDI ecu and harness and all set!
Old Jul 17, 2003 | 11:16 PM
Loveless's Avatar
Default Re: obd1 (p1ccoloz)
rev limiter will not help when you mis shift
Old Jul 17, 2003 | 11:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">rev limiter will not help when you mis shift</TD></TR></TABLE>
so you mean to say, if i put my completly stock car in neutral, when i rev it, that it will go past 8200 RPM??? rev limiter is there to try and save the engine. not help you shift better. i know it wont help you physically do anything better, but it will help protect your engine in the event you miss shift and slam the gas in nuetral.
Old Jul 17, 2003 | 11:52 PM
Loveless's Avatar
Default Re: obd1 (4DooRGiSzer)
what? when you mis shift chances are you already bent a valve or worse
despite the fuel cut off, the rpm is still high and doesn't drop to 0 like you'd expect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Because, regardless of how the rev-limiter cuts power (e.g. spark, fuel, etc.), the momentum of the car being transferred through the transmission back to the engine will continue to spin the engine and all of its components at a particular RPM. In other words, if a shift to 2nd will result in 10,000 RPM at a particular road speed, the engine speed will indeed be at 10,000 RPM (assuming the clutch is out) even if the engine is receiving no fuel or spark. </TD></TR></TABLE>
Old Jul 18, 2003 | 12:08 AM
SHystrdyGSRtdy's Avatar
$75 harness from some guy built buy some shop he never used and a $185 p72 obd1 5 spd gsr ecu used but 2nd owner never used.... i searched for best prices
Old Jul 18, 2003 | 12:36 AM
Loveless's Avatar
Default Re: obd1 (iLUVmySH)
there was a thread about some guy who did his own harness and set his car on fire
nothing_shocking
Engine Management and Tuning
Dec 1, 2010 04:00 PM
E.
Apr 21, 2008 08:40 AM
mrx
Feb 25, 2005 12:36 AM
C_I_V_I_C
Nov 5, 2003 05:26 PM
Type R
Jun 18, 2001 12:38 AM
