Knuckle problems
Old Dec 15, 2019 | 04:46 PM
ginger7720's Avatar
Default Knuckle problems
So I have a 1998 Acura integra and I accidentally broke 3 lug nuts and where I live nobody had a knuckle for me to buy so I can swap it so I was wondering if a 1995 Acura integra knuckle can fit in replacement for it
Old Dec 16, 2019 | 08:05 AM
dc2iggy's Avatar
10 Year Member
Default Re: Knuckle problems
It would probably be easier to just replace the studs. Hammer out the old ones and feed the new ones in. As long as they are the oem size it should be an easy install.
Old Dec 16, 2019 | 02:30 PM
ginger7720's Avatar
I can’t because behind the studs there a little lip that prevents me from replacing them unless I cut a grove into the knuckle but idk what do you recommend
Old Dec 17, 2019 | 10:28 AM
BiggieBert's Avatar
Loved
Community Favorite
A 95 will bolt up, but it may or may not have abs sensor and wire mounting points, if you aren’t abs (i doubt it) then not a concern.
Old Dec 19, 2019 | 06:16 AM
tony_2018's Avatar
Fish Twig
Some 95 models do have ABS, don't ask me how I know.
Old Dec 19, 2019 | 10:42 AM
MotorMouth93's Avatar
10 Year Member
Why not just replace the studs and the wheel bearing? A new Timken wheel bearing and lug studs is like $50 on rockauto. Beat the hub out of the knuckle with a big hammer, beat the wheel bearing out, take it to a shop and have them press in a new bearing, press in the studs, then press the hub back in.
GaryTuesday
Suspension & Brakes
Mar 5, 2019 03:45 AM
216.226.142.95:27016
May 6, 2009 11:52 AM
bigislandc2
Jul 11, 2007 09:31 PM
ernald711
Suspension & Brakes
10
Mar 6, 2006 10:46 AM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
