Compression test w/ broken timing belt??
Hey all... spring is here & I'm starting to work on my car. My question is, can I do a compression test with a snapped timing belt, or do I have to put a new one on to test?
I don't want to put everything back together just to find out if one of my valves is bent, then have to rip everything apart again. Any advice or help would be appreciated.
Thanks!
'95 integra GSR, black/black
Mods:
USDM Type-R Trans
Exedy organic clutch & lightweight flywheel
RS*R Ex-Mag exhaust, straight pipe, ebay Type-R copy 4-1 header
Tein SS coilovers
rollin w/ the fat 5's (for now)
I hate wisconsin
Thanks!
Mods:
USDM Type-R Trans
Tein SS coilovers
I hate wisconsin
everything has to be in time to measure the compression of each cylinder, so yes you need a timing belt on it.
You could carefully set the crank so that the piston you're testing is in the middle of the cylinder, and all 4 valves over that cylinder are closed. Then using a leakdown tester, you fill the cylinder with compressed air and see how much leaks out. If it leaks out quickly you have bent valves more likely (double check to make sure all valves are closed). If it leaks out very slowly (some will leak out no matter what) then that one is probably okay.
To get the pistons and camshafts in the right place for each cylinder, you'll probably need to turn each a little at a time so that the pistons don't touch any of the valves.
Wesleycrx
Dec 7, 2014 10:24 AM
RockLee`
Oct 29, 2006 03:43 PM
