best front camber kit ?
well purchased my omni coil-overs and ive already got the spc rear camber and toe kit... but need something for the front now.
whats a good one to get? ive heard of problems with all the different types..
Re: best front camber kit ? (Jason84)
i am dropped with neuspeed sports, and rockin the skunk2 front camber kit, using the washer trick in the back. works great for me!
Question is, how much are you going to lower it (height you will keep it at for the majority of the time)? This will determine how much adjustment you will need. However, with coilovers, you should get a control arm kit as they will give you the most adjustment range and allow you to take your vehicle from stock height to slammed. Therefore, you can go with SPC, Ingalls, Skunk2 or OMNI. Currently we are running a special on the OMNI arms. Checkout the link below and email me if you have any questions.
Re: best front camber kit ? (clint g)
im usin the omni front control arms, work great. They have a good range of adjustment (4 degrees) and they also match with my omni coilovers. I would replace get a whole control arm as said above, you will be happy.
decode22
04-16-2006 03:26 PM
MidwestSi
03-09-2005 04:15 PM
awalk2005
07-08-2003 09:36 PM
