fuel filter replacement
Old Apr 14, 2005 | 12:57 PM
FullRaceCRX's Avatar
Default fuel filter replacement
I have a 90 teg and am going to replace the fuel filter anyone know a web site or wana tell me how i do that,
thanks
Old Apr 14, 2005 | 01:02 PM
G1 TEGGY's Avatar
Default Re: fuel filter replacement (90tegGS)
keep checkin back to this place for your FSM to pop up.. http://carfiche.com/manuals/
it seems the gen2 fsm link is down right now
Old Apr 14, 2005 | 01:09 PM
Slain's Avatar
its easy take off your intake tube...look at the firewall and below that is your fuel filter.... pop your gas lid and relieve the pressure by removing the gas cap. have a few rags by you because removing the two bolts will cause a little gas to come out no biggie.
Old Apr 14, 2005 | 01:22 PM
Default Re: (Slain)
thanks sounds ez enough
Old Apr 14, 2005 | 01:23 PM
G1 TEGGY's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">its easy take off your intake tube...look at the firewall and below that is your fuel filter.... pop your gas lid and relieve the pressure by removing the gas cap. have a few rags by you because removing the two bolts will cause a little gas to come out no biggie. </TD></TR></TABLE>
do the gen2's still have the banjo washer that you're supposed to replace though? i know the gen1's did
Old Apr 14, 2005 | 01:30 PM
r3v da t3g's Avatar
Default Re: (G1 TEGGY)
Umm dont you have to disconnect something electrical underneath the back seat?? I just did mine today and i followed instructions on team-integra.net for G3 tegs, don't know its the same or not. Can someone clear it up?
Old Apr 14, 2005 | 04:36 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (r3v da t3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">Umm dont you have to disconnect something electrical underneath the back seat?? I just did mine today and i followed instructions on team-integra.net for G3 tegs, don't know its the same or not. Can someone clear it up?</TD></TR></TABLE>
That's just one method for releiving fuel pressure: disconnect fuel pump and crank engine over a few times. I just remove the gas cap myself.
G3's have a washer for both sides of the banjo bolt, so I would assume G2's do also.
Actually I'm pretty sure that banjo bolts and fittings ALWAYS have 2 washers. one for both sides of the fitting. Fuel filter does, brake calipers do, etc.
Old Apr 14, 2005 | 04:56 PM
G1 TEGGY's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Actually I'm pretty sure that banjo bolts and fittings ALWAYS have 2 washers. one for both sides of the fitting. Fuel filter does, brake calipers do, etc.</TD></TR></TABLE>
thought so, thanks pat.. it's always a good idea to replace those suckers
Old Apr 14, 2005 | 06:13 PM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G1 TEGGY &raquo;</TD></TR><TR><TD CLASS="quote">thought so, thanks pat.. it's always a good idea to replace those suckers </TD></TR></TABLE>
Yes, it is, they will come with your OEM replacement fuel filter. I think there are 5 of them, 4 are the same size, and there is a small one for the top service bolt. Here is the Helm's page on changing it for a 93 Integra. I prefer doing it on my G2, because both lines go into the top of the filter, as opposed to the G3 where one goes on top and one on bottom. On the G2 it is easy as pie, have fun!
As for relieving pressure, like Pat says, I just take off my gas cap, and then I loosen the service bolt on the right side. You will still get a little bit of gas leakage, so just put a towel under the filter, it will stop pretty quickly.
04AccordEX
Jan 23, 2008 06:19 AM
Blamm!!
Feb 5, 2007 07:59 AM
joshuaaaronalpert
Jun 8, 2005 08:12 PM
NCTUAN03
Apr 20, 2005 07:37 AM
ArchAngel Sabastian
Sep 20, 2001 01:42 PM
