engine swap...
Old Apr 14, 2005 | 11:39 AM
typeRobtypeS's Avatar
Default engine swap...
i have a 94 LS with 140,000+ miles on it. The tranny is bad not to mention its automatic. Ive been thinking about an engine/tranny swap and eventually turbo. Would it be worth it to spend the extra money on a gsr or should i stick with an ls considering the lower compression? Also which one is cheaper or more reliable to build if im going to be running higher PSI?
Modified by typeRobtypeS at 1:18 PM 4/14/2005
Old Apr 14, 2005 | 07:56 PM
Default Re: engine swap... (typeRobtypeS)
bump
Old Apr 14, 2005 | 08:15 PM
Deep's Avatar
You'll make much better hp with the GSR but the LS is cheaper. Anyway you go just make sure you add boost...
secor1408
Oct 18, 2008 06:48 AM
S1NFUL RL1 619
Aug 24, 2006 06:38 AM
Drew17th
23
Oct 31, 2005 12:50 PM
IntegraDriver
Feb 9, 2005 08:11 AM
