CEL 43 Help!
Old Jun 13, 2012 | 04:05 PM
mdrshewrote's Avatar
Default CEL 43 Help!
Just got a high flow cat done and when I drive for a few minutes the CEL will turn on also I do notice it usually turns on asap when I'm on the freeway. I also smell carbon and my mpg is horrible... First thing I've done is switch the fuel filter and still have this problem. Any suggestions? Thanks.
Old Jun 13, 2012 | 08:05 PM
Default Re: CEL 43 Help!
Anyone? Ttt
Old Jun 14, 2012 | 04:01 PM
TheRealTegger's Avatar
Year?
Make?
Model?
Engine?
Transmission?
ECU/ECM?
Harness?
Any and all mods besides the high-flow cat?
Code 43 is set when the ECU/ECM can't make up its mind whether the oxygen sensor is responding incorrectly to ECU control, or the fuel pressure is incorrect.
Old Jun 14, 2012 | 11:11 PM
Solster's Avatar
how big is the pipe for the exhaust from the cat back?
Header?
is the O2 even pluged in?
Old Jun 15, 2012 | 12:37 PM
96 gsr, 99 tranny, chipped p28 on gsr basemap. OBD1. Only mod is IM and 2.25 hi flo cat, everything is stock, headers and b pipe. Yes o2 is plugged... Ttt
Old Jun 16, 2012 | 07:23 AM
delsolintegra's Avatar
Things to check.
Is the oxygen sensor good?
Could the exhaust manifold have a hairline crack?
Fuel Pressure regulator o-ring renew with silicon grease or replace.
Old Jun 16, 2012 | 07:57 AM
el crapitan's Avatar
code 43 is set when the pcm believes there is a fuel related issue. although many times it's not a fuel related issue, but rather only the ecm's interpretation of it.
first thing that needs to be accounted for is fuel pressure/flow.
install a fuel pressure gauge at the supply line after the filter. KOER, observe pressure. pinch the vacuum line off fuel pressure reg. pressure should rise approx. 8-10psi. if not, replace the reg. if good, with reg still pinched, snap the throttle 3 times to approx. 3k. pressure should not deviate more than 2 psi. if it does, there is a flow issue, ie, failing pump.
this is a great test for confirming FPR operation and flow
while the fuel supply is not the #1 cause of a code43, it must be disqualified.
try that out and see what you get and we can move further
Old Jun 16, 2012 | 01:45 PM
I'm getting a new O2 sensor and headers just cause then I'll check with the fuel regulator... See what happens. Thanks guys!
Twest77
Oct 18, 2012 05:54 PM
Crazyxc2448
Mar 25, 2010 03:56 PM
D3U1LT
Sep 20, 2004 05:24 AM
AzianAvenger
Aug 6, 2001 06:46 PM
