Starter issue
Old Jun 5, 2012 | 05:10 PM
viciousvisionslarry's Avatar
Default Starter issue
hi guys i bought a 95 ls with a bad motor. I swapped in a b18b out of a 97 integra everything is cool with the swap now the starter is acking up. It was just replaced now its clicking. Itll start is i keep messing with the key but it clicks the first couple times i turn the key. The starter was perfect before the motor swap.
Old Jun 5, 2012 | 05:13 PM
integra_101's Avatar
Default Re: Starter issue
check the ground wire that runs from the starter to the front clip
Old Jun 7, 2012 | 12:02 AM
Ok I don't have a ground wire on the starter where would I be looking for the wire to come from or go to?
Old Jun 7, 2012 | 06:10 AM
fcm's Avatar
fcm
Old Fart
There is no ground at the starter, the starter grounds through it's case.
Your problem may be a grounding issue, to check, leave door open so dome light stays on, watch dome light as you try and start the car, if the dome light goes out when you hear the "click", you have a grounding problem, redo your main grounds, batt. cable clamp and post, batt. to chassis ground and chassis to engine ground.
If dome light does not go out it is not a grounding problem and is most likely the high current contacts in the starter motor solenoid... https://honda-tech.com/forums/showth...+starter+motor 94
Old Jun 7, 2012 | 07:53 AM
my 01 integra has a ground wire going from the starter to the front clip. aswell as my 1990 integra
Old Jun 7, 2012 | 10:50 AM
fcm's Avatar
fcm
Old Fart
Never seen a ground lead/cable on and Integra starter, and all the wiring diagrams I have looked at do not show one.
Some thing added maybe, post a pic of them.
Not even sure why it would need one as the starter grounds through it's case to the engine, [transaxle] 94
Old Jun 7, 2012 | 10:54 AM
sorry, it doesnt run to the front clip. it runs to where the air intake is. that platform.
Old Jun 7, 2012 | 11:28 AM
fcm's Avatar
fcm
Old Fart
Pic please. 94
Old Jun 7, 2012 | 11:45 AM
kyden's Avatar
there is no ground wire on the starter.
Old Jun 7, 2012 | 12:09 PM
i cant find one. but ill take a pic of mine. its a brown wire.
People have issues with this because they put the wrong starter in their car and the ground wire burns and melts.
Old Jun 7, 2012 | 12:24 PM
kyden's Avatar
again, no.
hondachris1994
12
Nov 9, 2017 05:15 PM
crxjatt
16
Jul 16, 2013 03:08 PM
Shaw14
Mar 6, 2011 04:58 PM
twentyhurtz
Dec 14, 2009 12:28 PM
candyman206
Feb 9, 2006 10:09 PM
