2STEP WHILE DRIVING?
Old May 31, 2012 | 12:20 PM
slammedinteg's Avatar
Default 2STEP WHILE DRIVING?
okay so i have a b16 in my integra and i just put an oem harness in my car. everything worked fine as far as starting the car the night before. i woke up the next morning and the car wouldnt start. i also noticed my speedo wasnt working and my car wont rev over 4200 rpms... even with my a/c on to disable two step. i've tried two different ecu's and the only thing i've changed was my harness. i would love to put the harness i built back into the car but i chopped it in half as i was pulling it out so now i have to rebuild it. any ideas to what maybe this could be?
Old May 31, 2012 | 01:04 PM
KYDelSol's Avatar
Default Re: 2STEP WHILE DRIVING?
I've had this happen to my GSR. Since the computer thinks your not moving it always has the 2 step ready to engage. Try cleaning out the speed sensor on the tranny. I pulled mine out cleaned it up a little bit and it worked.
Old May 31, 2012 | 01:06 PM
Dc4LsTeG's Avatar
EK9
X2 try fixing the Speedo problem first. Did you try a stock ecu?
Old Jun 1, 2012 | 04:41 AM
no i didn't i don't have one around here really available to me.. i'm gonna try to fix the speedo problem and go from there..
Old Jun 1, 2012 | 09:26 AM
alright well i fixed my speedo problem and its still doing it. i put a gsr ob2 cluster in my car. do you think it might have something to do with it since my car is obd1
Old Jun 1, 2012 | 09:39 AM
Solster's Avatar
ok i have not heard the term 2 step befor will some one please explain this to me?
i ask cuz it looks as thought the ECU needs to see a VSS for something.
i have a 91 Teg with GSR running on a stock P72 OBD1 ECU and if i need a vss it might just be the Push i need to go for the 94+ cluster swap i have been thinking about doing.
Old Jun 1, 2012 | 09:41 AM
JuggerNaut-CTR's Avatar
full throttle launch control
Old Jun 1, 2012 | 09:42 AM
Solster's Avatar
as long as the Pin out of the connectors is the same you should be fine
Old Jun 1, 2012 | 09:44 AM
Solster's Avatar
Thank you.
i don't have that. But i'm still thinking of doing the cluster swap and doinf a write up on it for other gen 2 owner's.
Old Jan 14, 2013 | 02:43 PM
jameshuller's Avatar
any luck with fixing the problem? my ls vtec is also doing this, obd1 block- obd2 head, obd1 to obd2 conversion harness, and full throttle launch control also revving at 4500 while driving
Old Dec 18, 2018 | 05:34 AM
Sean Barbosa's Avatar
Did u ever find the fix, im having a similar problem with my launch control, its reving and 2 stepping as soon as i turn it on
Old May 7, 2020 | 08:16 PM
813kevin's Avatar
So I know this thread is very old, but in case anyone is on here that is currently having the problem I am going to explain what I did to fix it anyways. I had a full LS in my ek chipped on p72 with base map and 2-step. My speedo also wasn’t working and my car would not rev past 5k because the 2-step would engage. I then checked the fuse diagram and checked out fuse #15 and it was blown. I replaced the fuse and my speedometer was working and I could rev to redline again. But if that is not the problem for you I would also check the VSS itself to see if the ribs on it look very worn and also to see if it rotates both ways smoothly, even though it’s un-Likely that the VSS went bad. Also check the clip itself.
Old May 8, 2020 | 11:52 AM
wunfstgsr's Avatar
Loved
Community Favorite
Thanks
NA James
Jan 24, 2011 12:17 PM
b16balfamale
11
Jan 14, 2009 07:55 AM
JDMcb7
Transmission & Drivetrain
Dec 23, 2008 07:00 AM
